ford small block bolt issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2009, 10:41 PM
I have a friend that took his engine in and had it rebuilt, they removed all the accessory's water pump, carb, exhaust manifolds ect.... I can handle the installation of all these items, but what I have found is I dont know which bolts are which. Let me tell you I have a box of bolts some to this engine and alot that are not. On a small block chevy, I can go thur it blind folded, but have never messed with a ford. does anyone Have all the bolt specs on a small block ford. rather then go buy a bolt kit. I'd rather go down and get them from local bolt company. So specs would be great guys thanks in advance for all help
Old 08-01-2009, 11:04 PM
generally on ford small blocks the water pump and timing cover bolts are 5/16 but the length is to be determined due to ford used many different timing cover and water pump combonations throughout out the years, the intake will be 5/16 or 3/8 and generally 11/4 or 11/2 long. manifold is 3/8 and length is determined by manifold your using, alternator and power steering brackets should be 3/8, and carb is 5/16.
what small block do yu have? jst curious.
Old 08-02-2009, 06:24 AM
1982 f150 -5.8 liter, 351
Old 08-02-2009, 02:15 PM
scrot's Avatar
Originally Posted by stinger460
..................are 5/16 but the length is to be...... the intake will be 5/16 or 3/8 and generally 11/4 or 11/2 long. manifold is 3/8 and length is determined by manifold your using,.... should be 3/8, and carb is 5/16.
Are you refering to the actual diameter of shank of the the bolt, or to the size of the head, and the size of the socket that fits on it?
Small block Ford steering conflict rhphotrod Engine 5 07-27-2007 04:32 PM
ford small block in 48 ford pu what headers hemivolvo Engine 0 07-20-2007 05:02 PM
Ford Small Block bellhousing woes falcondan Transmission - Rearend 5 07-07-2007 03:21 AM
2 bolt vs 4 bolt main 350 small block CanadianCory Engine 9 10-30-2005 10:31 PM
small block selection price and 2 bolt vs 4 hotrod66_57 Engine 8 07-20-2004 01:35 PM
