Ford Smith 9000 lbs Tec 9 hoist - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2008, 08:57 PM
just moved to a new shop and have a problem with one of the hoists....it's a Ford Smith 9000 lbs 2 post hoist about 5 years old on the master side where the controls are the one arm goes down slowly by itself. When I raised the hoist they both go up together, but if you wait, the one side slowly leaks downward....only happens on the master control side. Has anyone experienced this problem?
Old 04-01-2008, 09:23 AM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
I wish I had a hoist....
In a while, Chet.
Old 04-03-2008, 06:02 AM
schnitz's Avatar
Wiki Edits: 54
Just bumping this up again. Just a hunch as to why it's going down slowly on you would be a bad seal on the lift ram. Might not be (I've never even heard of a Ford Smith lift so I'm not familiar at all with the setup), but it's worth a shot.
In a while, Chet.
Old 04-14-2008, 09:05 PM
New Member
In a while, Chet.
Hoist? What type of hoist are you looking for???
_____________________________________________
Latest bmw 525i | Latest bmw 525i a/c condenser
Old 04-14-2008, 09:17 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
I would make sure the safety catch (ratchet type mechanism) is working. It's normal for the ram(s) to leak down slowly, that's why if the car has been on the lift very long you usually have to raise the car a bit to get it off the safety catches so they'll release and you can lower the car.
Old 04-17-2008, 10:40 AM
tec 9
the problem could be two fold. one could be the seals in the cylinder could be going bad. the other could be the release valve could have trash in it. to fix the valve be sure and hit the up button and at the same time hit the release lever. this will flush the system out. the parts for this lift are very limited. if it is your cylinder leaking down you should be able to take it to a hydraulic shop and have them rebuild it.
Old 04-17-2008, 06:02 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
The reason I suggested the safety catch (mechanical) is there is no way it can leak down if the safety is working. It'll go down a hair until it catches the safety and that's it. I have yet to see a lift that uses only the rams to hold and I sure as hell won't work under it.
Old 04-18-2008, 03:55 AM
tec 9
the safety catches are a good idea. it use to be the power unit would hold up most cars but in today's world the power unit even has a tag on it saying this is not a load handling device. it is always suggested to lift the car or truck to the position you want it then lower it back onto the lock. if you don't then it is possible to blow out the power unit seals along with the seals in the cylinders.
Explorer Disc Bbrakes on a 9" Ford Rear End Mustangsaly Suspension - Brakes - Steering 2 10-31-2005 04:18 PM
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 05:29 AM
Henry Ford in Heaven schnitz Hotrodders' Lounge 9 10-19-2004 10:09 AM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
1970 Ford Clay Smith cam mustang Engine 1 09-30-2002 09:14 PM
