No, it will not handle continuous duty, and will burn up(overheat) in a matter of hours, if not minutes. On time I tried it, it was about 20 minutes of on/off testing of the wiring harness, and it failed as soon as we tried to actually run the car for more than a few minutes. Never even made it to the road.
It is a high current, intermittent load relay. You need a high current, continuous load relay. |
I use that type of solenoid on my Meyers snowplow....but it is only short periods....I have gotten it warm, but hasn't failed.
They do make similar solenoids for RVs to keep the auxiliary battery charged.....Maybe taht would work for you
Ontario Rodders |
Absolutely, you need a Solenoid Relay Switch Continuous Duty. You can get a 100 amp one for about 25.00.
![]() example: 100 amp continuous duty relay. Keeps all the high amperage under the hood where it belongs. Use your pressure switch and or on/off toggle switch to turn relay on and off. Made in the USA by PrestoLite. Last edited by Denny; 11-18-2009 at 09:25 AM. |
| Ford 9 Inch Posi Swap | 31fordcoupe | Transmission - Rearend | 11 | 11-06-2009 09:38 AM |
| Chopping a 9" housing | 31fordcoupe | Transmission - Rearend | 7 | 07-28-2009 06:50 PM |
| Ford Muscle..what's wrong with them? | tm454 | Hotrodders' Lounge | 41 | 11-20-2006 12:37 PM |
| M.S. requested joke thread | hotrodit | Off-Topic | 186 | 12-20-2005 12:26 PM |
| 427 or 454? | frankenvette | Engine | 50 | 06-05-2005 10:12 PM |
