Ford solenoid on Chevy starter ??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-12-2009, 08:23 AM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
I'm planing in doing the popular ford solenoid conversion to cure hot starting problems on chevys, and I'm wondering if a different way would work better:
the usual way is splicing the solenoind in the bat cable, ok, but then this cable goes to the original connector on the starter motor solenoid and a jumper is connected from here to the "S" terminal on this solenoid, fine this will get full bat voltage to THE SOLENOID, not to the starter motor's windings, we still rely on the contacts inside this solenoid to get full juice to the motor, I'm thinking that the Bat cable should be connected directly to the other side of the solenoid, the one that holds the motor's wounds so the full voltage goes where it's needed, and not hampered by a poor contact inside the solenoid, which by the way still needs the jumper wire to the S terminal to activate it and engage the bendix.
what is the point installing a ford solenoid and still relying on the chevy solenoid to deliver full voltage to the motor's windings?
What do you guys think about this reasoning?
Augusto.
Old 08-12-2009, 08:44 AM
Augusto.
You actually have hit on the crux of the problem. The usual method of wiring the Ferd solenoid on a GM starter STILL requires the contacts inside the GM solenoid to work. The only advantage to this method is that you have significantly reduced the voltage drop in the wire that operates the GM solenoid, thus the improvement in hot starting.
Unfortunately, the method you are contemplating does not work without making changes to the internal wiring of the GM solenoid. The solenoid must still operate to move the Bendix drive into place on the flywheel. The internal wiring of the solenoid has two paths, one high current path to move the Bendix and a lower current path to hold it in. If you wire the Ferd solenoid the way you suggest, the internal wiring in the GM solenoid will cause the starter to stay engaged at all times.
Since you are stuck using the GM solenoid, there is an even easier way to fight the voltage drop. Disconnect the wire going to the "S" terminal on the GM solenoid. Wire a relay (or a Ferd solenoid) between the battery terminal on the GM solenoid and the "S" terminal. Keep these wires as short as possible and use heavy gauge wire. Use the wire that formerly went to the "S" terminal to operate the relay. You now have bypassed all the voltage drop in the wiring that goes to the ignition switch and neutral safety switch, which is about the best you can do with the GM starter. This should solve any hot start problems anyway.
Old 08-12-2009, 08:47 PM
Augusto's Avatar
so if the GM solenoid won't work rigth, you say it will stay engaged all the time, I was thinking it could move the bendix too late, way after the motor started to turn, making the gear engagement noisy, then the ford solenoid does not make much sense really, the bosh 30 amp relay would be a much better option.
of course as you say short wires and sure soldered terminals would work fine,
there is no point in cutting the battery cable, take a look at the attached image I got from a chevelle's site
Old 08-13-2009, 09:08 AM
Yes, that is exactly what I was suggesting, however to make the voltage drop even smaller, I would run the wire to terminal 30 on the relay from the large terminal on the GM solenoid instead of running a wire all the way back to the battery.
Old 08-13-2009, 12:59 PM
Augusto's Avatar
yes, you are correct about it.
thanks a lot for your comments.
Augusto.
chevy starter, how to wire it? exline Electrical 8 04-29-2009 10:28 AM
12volt Starter for a 54 Chevy with a 235 engine. Riot Racing Engine 8 04-26-2009 02:22 PM
Ford vs Chevy question savman1 Engine 31 10-14-2008 07:13 PM
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 05:29 AM
Poor Chevy Guy Needs help from F..F..ford Pro's 11echo Transmission - Rearend 3 10-06-2004 06:06 PM
