Ford solonoid for a chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2012, 05:47 PM
A little help guy's if you would. please correct me if Im wrong on how the ford solonoid works. Power comes from the battery to one side of the solonoid, when the key is turned on the [I] terminal on the solonoid has power and when the key is turned to start from there power goes down thru the neutral safety switch to the [
Old 06-11-2012, 05:52 PM
continued
power goes down to the [S] terminal on the solonoid and out the side to the starter. so the only time the ford starter has power on it is when it is activated by the ignition switch turned to start. bill
Old 06-11-2012, 07:51 PM
EOD Guy's Avatar
Kinda.....There is a small stud and a larger stud and two very large studs.
The small stud goes to the coil (not sure on this).
The larger stud goes to the Start position on the ing switch.
The very large studs..... one goes to the battery and the other goes to the stater.
The body of the solenoid must be attached to a ground.
When you apply voltage to the larger stud, the solenoid functions and allows voltage to go to the starter.
Old 06-11-2012, 08:39 PM
LATECH's Avatar
S terminal is from "start" posistion of ignition switch. As EOD said, it energizes the coil , which activates the solenoid. One large terminal is for battery connection, the other side powers the starter when the solenoid is energized.
The "I" terminal is to power the Ignition system while cranking the starter. It bypasses the resistor circuit of the ignition system , to supply the ignition with full battery power to aid in starting (points) . On the duraspark II systems it retards the ignition timing VIA the white wire, to aid in starting the engine.
Fact is stranger than Fiction
Old 06-11-2012, 09:51 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
read
http://en.wikipedia.org/wiki/Solenoid
vicrod
Old 06-12-2012, 04:51 AM
EOD Guy's Avatar
Latech, didn't know for sure on the small stud on a Ford application, been using them forever on GM engines mounted in boats......so I didn't know for sure.
Chevy vs Ford golferjc Hotrodding Basics 16 02-13-2011 02:54 PM
Ford vs. Chevy Mr.Fixxit Hotrodders' Lounge 21 10-23-2009 08:35 PM
Starter solonoid question???? HemmiGremmie Electrical 4 08-29-2003 03:46 AM
starter and solonoid wireing ford 289 76 jamesbiggg Electrical 0 08-05-2003 03:59 PM
Ford Solonoid on a Chevy ???'s juveteach Electrical 2 06-21-2003 08:29 PM
