Originally Posted by Dajerseyrat
I have a 302 equipped with SVO Aluminum heads (GT40X) and I installed a set of stock replacement mustang 5.0 plugs gapped to .052 The car runs ok but idles like crap. It does sound like it has a slight misfire at idle at times and just does not seem to have the power it should. The plugs are clean when I take them out,very clean...All of them..So its not fouling out.
Then I come to find out that there is a completely different part number and plug for the aluminum GT40 heads. do you think failure to use the correct plugs is my issue?
I also suspect the wires being the culprit, cause it was the first set of wires I crimped myself and was unsure of myself...
The stock iron head plugs like 25's are 1/4" too short- so yes they could be causing the bad idle. Do not run them any more than absolutely necessary, the exposed threads of the head will be filling up w/carbon and could- given enough time- make installing the longer 764's (or whatever you end up choosing) hard to install.
Do not forget to use antiseize on the threads and remove the plugs w/the engine cooled off, not hot.
