Ford starter/flexplate - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-09-2013, 11:01 PM
Last journal entry: studebaker m5
I installed a 302/fmx into my 1955 willys truck.I put a new starter in the truck.Well,i thought the starter was a bit loud when it cranked over,maybe it was loose? so i checked it.Nope it was tight..it was working so i left it alone.NOW it was getting louder,then it reached a point where it would engage the flexplate teeth.What i found was that roughly 80% of the teeth on the flexplate are literally ground off,so the truck wont turnover at all.Im in the process of yanking the engine and replacing the flexplate.Im being told that i needed to shim the starter,But none of the parts stores seem to know anything about ford starters needing to be shimmed,I never have needed to shim any ford i ever drove,never had starter issues like this.Do i need to shim a starter for a plain old 302/fmx?..and again i have asked parts stores for a shim kit.but they cant seem to find such a thing for fords until the 90's vehicles
Old 04-10-2013, 08:00 AM
Banned
look at this shim kit. Jegs Performance Products 10029 Starter Shim Kit | eBay
starter or flexplate truckboy61 Engine 1 08-23-2009 06:36 PM
flexplate and starter issue v8 dan Transmission - Rearend 2 12-17-2008 08:00 PM
Starter grinding the flexplate 92z28400sbc Engine 11 01-12-2008 08:56 PM
flexplate/starter interference stanjr41 General Rodding Tech 4 02-09-2006 09:57 PM
Starter too far from flexplate leastbay Engine 8 09-02-2004 04:07 PM
