Ford Starter Relay Ground - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2010, 07:06 PM
boris_thespider's Avatar
I might have to mount my Ford starter relay to my fiberglass firewall. So, I'm going to have to run a ground wire from the starter relay housing to the steel frame. How much current will this ground wire need to handle and what gauge wire should I use? Thanks...
Mike
Old 02-11-2010, 07:48 PM
302 Z28's Avatar
A #12 AWG ground wire is more than sufficient. That is exactly what I did to my 34. You might consider a ground terminal strip in the trunk area if that is where your starter relay is mounted. It's a good idea even if you don't, makes it easy to hook up grounds for lights, fuel sender, and fuel pump.
Vince
Ford starter problems colcummings Engine 2 06-22-2009 08:05 AM
Ford Muscle..what's wrong with them? tm454 Hotrodders' Lounge 41 11-20-2006 12:37 PM
Old Ford Starter Button 3bytheknee Electrical 6 01-12-2005 08:54 AM
starter and solonoid wireing ford 289 76 jamesbiggg Electrical 0 08-05-2003 03:59 PM
MELTED STARTER RELAY Jim69Mustang Electrical 2 03-31-2003 03:35 PM
