Ford Steering Column Help wanted. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2012, 10:08 PM
Mr.Fixxit's Avatar
Ok, not sure if this applys here exactly. But the steering wheel does control the suspension. anyway. I have a '73 Mark IV Lincoln Continental. The Steering column was damaged when a thief tried to steal the car, thankfully the battery was low. They broke the shifter handle assembly right off the column, and must have used something to try and twist the ignition lock, the lock cylinder and all the internal mechanisms where bents twisted or stripped. I converted to a custom floor shift after this... But I need a Column Cap??? The Cast piece of the column that has the ignition lock in it. Can you retro fit any other later Model Ford Steering columns, equipped with Tilt Wheel and Cruise? Any of the round styled columns, like even the 1990's broncos or something?
Old 06-10-2012, 10:10 AM
The Flyin Wop's Avatar
Paisano
Last wiki edit: How to remove an ignition key lock
Wiki Edits: 4
No,the newer FoMoCo tilt collums are completely differant.Parts will not interchange.I used to do a lot theft jobs for when I was with ford for 36+ years.Replacement parts for older ones like a 73 were almost impossible to find from normal channels.
Paisano
'47 Ford steering column removal bgraham Suspension - Brakes - Steering 2 01-18-2012 09:16 AM
steering column for 40 ford howie1940-50 Suspension - Brakes - Steering 3 08-17-2007 05:18 PM
40 ford steering column Simon Rowell Suspension - Brakes - Steering 3 05-28-2007 08:00 AM
steering column 34 Ford rhphotrod Suspension - Brakes - Steering 5 03-27-2007 07:59 AM
34 ford steering column vette66guy Suspension - Brakes - Steering 3 06-01-2003 08:04 PM
