ford steering colums - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-04-2011, 10:15 PM
Have a steering colum app. 40 inches long out of 1989 lincoln. I require a colum 28 inches long. Do all Ford colums take the same plug ins as a lincoln or are they different? I am trying to install a wiring harness from the 89 lincoln into a 1959 F100 Ford.
Thanks Gary
Old 10-08-2011, 10:14 AM
35terraplane's Avatar
Ford steering columns
Thanks Gary
The plugs might be the same, but I"m not sure the color code on the wires are. Ford does like to mix things up once in awhile. I do have the color code for a 87 Ford T-Bird. But I'm not sure about the rest.
All older GM's are the same.
I know this didn't help but you will have to check the wires before you know. There are a couple guys on here that might know, this will get you started.
Bob
55 Ford steering fairlaneguy Suspension - Brakes - Steering 1 09-07-2011 02:14 PM
56 Ford P/u w/351 W P/steering solidaxel Suspension - Brakes - Steering 1 04-07-2010 03:31 PM
Best steering for 32 Ford p/u 09bigboy32 Suspension - Brakes - Steering 3 09-10-2009 04:37 PM
steering on a 51 ford car 51FordDuff Suspension - Brakes - Steering 1 04-09-2006 05:19 PM
steering colums squiggy2000 Suspension - Brakes - Steering 3 03-23-2004 09:23 PM
