Mustang Mags
The Early Mustang T 5 swap has been coverd several times in the Mustang magazines and you will find More info on the Various Mustang falcoln fairlane forums. how to set up the clutch, cable or push rod, hyd. etc. mounts etc. Mosty Chevy experts here. I just replaced the Clutch In my Fox chassis 84 Capri, I went to the 10 1/2 clutch, had to find a 87 and newer flywheel, And the pressure plate bolts were different, I ALWAYS save all the bolts-nuts when I pull parts in a bone yard. some pressure plates use a Y pattern on bolt layout, others are evenly spread around the circle. and you can have a 3 finger p plate or a multi finger spring plate.
oh okay, I took the flywheel back off and checked it out and it turns out to be a 28oz flywheel after all, but it's a smaller diameter for the newer T-5 Bellhousing. The clutch pressure plate only matches up in three places, but I think three bolts isnt enough for a pressure plate.
| clutch stuck to pressure plate | amature | Transmission - Rearend | 1 | 08-28-2011 07:21 PM |
| direct clutch pressure plate | runn141 | Transmission - Rearend | 3 | 12-02-2007 05:19 PM |
| Which clutch/pressure plate to use? | mrl | Transmission - Rearend | 6 | 01-12-2007 02:00 PM |
| 460 flywheel, 400 pressure plate? | billybob_v10 | Transmission - Rearend | 2 | 07-02-2004 11:51 AM |
| new clutch, used pressure plate? | chevyelc81 | Transmission - Rearend | 11 | 10-16-2002 04:14 PM |
