Ford T-5 with S-10 tail shaft? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2011, 12:06 PM
I need to move the shifter forward on a T-5 to run in my Model A. I'm running a 351W. Anyone have any experience in doing this?
Thanks for your help!!
Old 03-09-2011, 02:39 PM
Wiki Edits: 27
T 5
I was ato the SLC autorama last weekend and
Tremec had a booth there, I ask about Moving a T 5 shifter foreward and the tech said one area to be aware of is the Spedo drive differences in different T 5's T 5's were also used on some import cars. 20 year ago I took a trans to the band saw, cut off the shifter casting Moved it foreward, Tig welded it back to the housing and cut down the shift shaft. a lot of work. but got it out of the front seat area.
Old 03-10-2011, 08:49 AM
Do a Google search. This is very common in the street rod crowd and there are many, many web pages and forum entries that show how to do it.
Old 03-10-2011, 09:20 AM
It needs to be an early S10 tailhousing that was cable driven, there are some ways to fidget with the reluctor wheel setup...Im not sure of exactly what
Question on 700r4 transmission tail shaft and front shaft eric32 Transmission - Rearend 11 05-10-2009 12:03 PM
tail shaft ?'s bowtieboy792003 Transmission - Rearend 0 05-26-2008 03:49 PM
C6 tail shaft darrin Transmission - Rearend 2 07-13-2003 09:06 AM
tail shaft 1badcamero Transmission - Rearend 3 12-17-2002 01:59 PM
Ford Top loader tail shaft 65 stang Transmission - Rearend 1 11-28-2002 12:10 AM
