Ford tailshaft questions 4R70W vs. AOD - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2011, 01:06 PM
I'm in the middle of a 5.0 4Rw70 swap into an 1980 Volvo Bertone.
The space in the trans (driveshaft) tunnel seems to be very limited.
Since the yoke on the 4RW70 is rather big and 1.6 in diameter.
I'm thinking maybe swapping an AOD tailshaft so I can use the smaller yoke.
which is 1.5 in diameter.
The joint retainer width is 3.875 (the too big part) on the Explorer yoke.2-3-14061X
So........Is this a good option? Is there tailshafts from many models I could use or 5.0 specific AOD only?
Other ideas?
Hoping a trans expert can chime in.
Thanks!
Old 01-26-2011, 03:12 PM
LATECH's Avatar
Other ideas?
Thanks!
there is only 5/16 inch difference in the two yokes as far as width is concernd. the aod/aode/c-4 yoke is 3 1/4 and the 4r70w is 3 11/16. Not much difference.can you drop the trans tailhousing 1/4 inch on the crossmember?Can you mod the tunnel to fit the larger width?
Ford 4R70W torque converter interchange? sweet99 Transmission - Rearend 1 11-09-2006 04:04 PM
4R70W no go dbdbb Transmission - Rearend 2 09-09-2006 10:38 PM
Ford 4R70W Transmission won't shift 2-3 Arrowhead Transmission - Rearend 2 04-30-2006 06:22 PM
More Turbo 350 Tailshaft questions jamnut Transmission - Rearend 1 04-26-2003 12:55 PM
4R70W 00stang Transmission - Rearend 2 08-24-2002 09:32 PM
