Its a 3sp-OD
4 speed M.T. Ford, w/O.D. ID #s: ZR1173 1 MUSTAN 79 M.T., 8-302 2 MUSTAN 80 4SPD M.T., 6-200 3.3L 3 MUSTAN 81 4SPD M.T., 6-200 3.3L, w/OD 4 MUSTAN 82 M.T., 8-302 (5.0L) 5 MUSTAN 83 4SPD M.T., 8-302 (5.0L) 6 CAPRI 79 M.T., RWD, 8-302 7 CAPRI 80 4SPD M.T., RWD, 6-200 3.3L 8 CAPRI 81 4SPD M.T., RWD, 6-200 3.3L, w/OD 9 CAPRI 82 M.T., RWD, 8-302 (5.0L) 10 CAPRI 83 4SPD M.T., RWD, 8-302 (5.0L) |
is there a page i can go to for this info.i don't see the zr-1173 anywhere on this tranny.it has a metal tag riveted to it but the rust has taken its toll over the yrs.there is a number thats on it several times.i assume it's the vin#.the guy my buddy bought this tranny from advertised it as a 4 speed and i think he had been using it in a stock car.this trans was not from a capri or mustang that i know,it was just going to be used in one and then wasn't.so if there are any info site someone can point me to.oh yea,i did take it to a tranny shop but the guy wasn't sure which one it was.thank you for trying.
Two versions were available. Starting in 1974, it was a cast iron case with external shift rods. It later went to an aluminum housing with internal rails (SROD). |
no,the tag has had it.i used a rotary wire brush on a drill and the tag cleaned up nicely.you just can't read the #'s.it is 82 or after.the tranny guy i had look at it saw some kind of a weird shaped bolt head that you use a star driver to take off with and said they started using them around 82 or 84.i have the bell housing and cable to go with it and its hyd. and i know the tranny is the srod type.i just want to find out what i have so i can figure out what to do with it.maybe i can take the tag off and put something on it like acid to help bring out the #'s.
| 51 ford tranny | 51FordDuff | Transmission - Rearend | 2 | 09-24-2004 06:45 PM |
| ford tranny swap | Ian70Mustang | Transmission - Rearend | 2 | 03-13-2004 07:44 AM |
| Pulling motor/ tranny 66 C10 | 66thom | Engine | 6 | 10-27-2003 09:46 AM |
| wanted, ford tranny . u pick | mikeweyman | Transmission - Rearend | 7 | 05-29-2003 01:51 AM |
| ford 9 inch please help i.d. | martion | Transmission - Rearend | 0 | 05-25-2003 09:16 PM |
