Ford Tranny Stuck in Drive - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2010, 01:31 PM
Senior Shadetree
I have an 84 Mustang GT350 ConvertibleV8 with OD auto tranny. I recently pulled it out of the garage to wash it after it had been sitting for about 6 months, and it apparently stuck in Drive. I have no Reverse, Neutral or Park. I checked the linkage and it is intact and moves as it should. Does anyone have a probable diagnosis? Can this be fixed without pulling the tranny? Help!
Old 11-19-2010, 05:07 PM
SSedan64's Avatar
Linkage on side of Trans moves as it should?
Old 11-19-2010, 08:04 PM
Senior Shadetree
Yes, everything on the outside of the tranny seems to be working as it should.
Old 11-19-2010, 10:01 PM
SSedan64's Avatar
AOD Trans? Not AODE?
Maybe the Manual linkage inside the Pan came loose. I doubt the Forward clutches could be stuck from just sitting.
Friends Dad had a Grand Marquis, sat a lot. His TCC/TorqueConverterClutch somehow got permanently locked while parked. Wouldn't start or anything. I told him that it probably was the "TCC" but, he took it to a Local Ford Dealer, charged him $1800 My Brother in law at the time worked for a Trans shop, said they would've removed/rebuilt/installed for $1200.
Old 11-20-2010, 09:26 AM
Senior Shadetree
Thanx for the interest. If it is the manual linkage inside the pan, can that be fixed without pulling the transmission out of the car?? The shifter goes through all the motions and the lever on the side of the tranny goes through all the proper "clicks", it just won't come out of drive. Also, it will start no matter where the shift lever is set now. The starter lockout is not working. It is an AOD tranny.
Old 11-21-2010, 12:15 AM
SSedan64's Avatar
Yes, will have to drop the Pan to check linkage to Manual valve.
Old 11-21-2010, 07:22 AM
Senior Shadetree
Thanx for the info. The next warm day, I'll jack it up, crawl under and check it out. You have a great Thanksgiving!
finally got to drive my 53 Ford jaslong Hotrodders' Lounge 2 07-22-2009 06:45 PM
ford shoebox 1951 tranny question ragnroll Transmission - Rearend 1 12-15-2008 05:50 PM
1978 ford f150 tranny 78F-150 351m Transmission - Rearend 3 06-08-2006 08:21 PM
wanted, ford tranny . u pick mikeweyman Transmission - Rearend 7 05-29-2003 01:51 AM
Ford auto tranny question??? cabrio Transmission - Rearend 1 01-30-2003 05:24 PM
