ford trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2007, 09:30 AM
ford trans
will a 3 speed trans from a 56 pick-up bolt to a 54 2 ton y-block bell housing this is all ford stuff
Old 08-06-2007, 01:36 PM
Wiki Edits: 27
old ford guy
As i remember the truck trans bolt pattern is alot bigger than the 3 speed pickup the 3 speeds from 1/2 tons usually were the car patern you need the belhousing to match the trans. some bigger trucks also used a larger clutch
List all of your cars HERE! Carbed95GT Hotrodders' Lounge 289 11-09-2011 06:43 PM
ford 400 with c6 trans... 68novafan General Rodding Tech 11 12-14-2005 10:56 PM
94 to 95 Ford Taurus engine and trans swap 406chevelle Engine 6 11-20-2005 02:14 PM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
1964 Ford Falcon Trans slip into 2nd whytyewytche Transmission - Rearend 0 11-27-2001 05:13 AM
