Ford trans question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2006, 04:10 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Ford trans question
I have a need for a tranny for a ford 4x4 and have a C-4 C-6 and an AOD..these are from 2wd cars and trucks.
Can the tailshaft be removed and a transfer case bolted up on any of these???..would save me a bunch if I can use what I already have..
Thanks
Sam
Old 09-29-2006, 07:34 PM
Arrowhead's Avatar
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
I'm thinking probably not. Here is a pictue of a C4 I took out of a 4x4 '74 Bronco. Notice the output shaft is quite a bit shorter than a regular 4x2 trans. You may be able to swap the output shafts, but your pretty much going to have to tear apart both transmission to do it, I believe.
Old 09-29-2006, 08:02 PM
Wiki Edits: 3
Worst case scene is that I will need another tranyy but hey we tried.. I will pull the rear housings on these and lookee see just what I have..
Sam
Crosley's Avatar
Wiki Edits: 1659
Thanks
Sam
No..........
Old 09-29-2006, 08:04 PM
Wiki Edits: 3
Originally Posted by Crosley
No..........
Foiled again..
Oh weel going tranny shopping then..
Sam
Old 09-29-2006, 08:10 PM
Crosley's Avatar
Wiki Edits: 1659
Ford uses a different shaft length for 4x4 applications from a 2wd setup.........
Old 09-30-2006, 04:24 AM
aka Duke of URL
Correct here. If you have a correct (or near correct) donor, you can interswap to make an origional if both are of the same basic design (consider all the running changes to a C4 for example). You would either have to be a very knowledgeable tech with a big tool box or know one you could trust.
Is your origional installation a C4 or C6 and what is the engine type? Transfer case type?
Old 09-30-2006, 04:48 AM
Wiki Edits: 3
Actually this is for the Ford in a Jeep project..Given the feedback I have located a complete unit..transmission and transfer case from a Ford Bronco..which I will go check out..
Doing the research on a 4x4 engine swap I found that a fellow needs to keep his engine and trans combo from the same donor as it solves a lot of issues..Putting the Ford engine and trans in the Jeep is made doable by the fact the Ford uses what we call a left side transfer case so the driveshaft outputs line up with the Jeep...
Thanks for the input..
Sam
« pump seal | 200r4 »
Ford rear main seal question. el pollo Engine 3 07-15-2006 09:12 AM
4l60e trans question silm man Transmission - Rearend 12 10-23-2005 03:10 PM
ford 302 fuel injection and aod trans 39 chev Engine 13 08-19-2005 09:49 PM
34 Ford fuel tank question 302 Z28 General Rodding Tech 1 02-01-2004 04:55 PM
Trans Question on my 2001 Chevy Silverado onebadmerc Transmission - Rearend 2 01-04-2004 03:04 PM
