Ford Transfercase Swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2006, 06:14 PM
What years will the Ford transfercase swap?
I have an older, pre 84 transfercase, will it bolt to a 92 trans?
Thanks
Old 02-06-2006, 09:35 PM
Totally depends on what T-case, what motor it was bolted to, what adapter it had on it. Need more details.
Old 02-06-2006, 10:01 PM
It's from an older ford, 4 speed, 302 motor, I want to use it in a 93 with a 351 motor. I haven't seen the 93 yet and was wondering if the TC I have might bolt to the 93 adapter? I'm used to old stuff, I don't know what fits what now? I think the newest truck I have still has round head lights!
Old 02-07-2006, 01:27 AM
Most ford trannies have the male 31 spline output shaft.
The 4 spd was likely a T-18/19 or NP435.
The older T-case probably has the round 6 bolt adapter, this should work behind the 93 transmission. The 93 probably had a BW Tcase so the linkage might have to be modified. You might have to use the adapter that was on the old ford to get the tcase to bolt up to the new tranny. I know it will if it's an auto, not sure if it a newer mazda 5 spd in there though.
Best way to tell is to make a template from cardboard and see if it matches up.
Old 02-07-2006, 04:05 AM
Thanks. I am seriously thinking of buying the newer Ford and knowing I have an older T cases here would be the thing to push me that way. I really won't know untill I buy it and pull the junk T case off.
Thanks!
Ford 5.4 swap garretthes Electrical 2 12-31-2005 07:41 AM
1937 ford engine swap dmoon11 Engine 0 02-07-2004 01:38 PM
1936 ford pu frame swap hippo General Rodding Tech 3 01-06-2004 12:05 PM
Ford Straight 6 swap to a 302 or 351 BillyBob1950 Engine 5 01-18-2003 03:42 PM
1940 Ford Delivery Chassis Swap New2theart Suspension - Brakes - Steering 5 07-19-2002 07:41 PM
