ford transit 2000 model steering biased 1 way - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2009, 04:21 PM
hi can any1 please tell me why my ford transit steering is heavy when i turn 1 way and the steeringwheel doesn't return to center, is this a minor problem or is it going to have to be taken to a garage for expensive repairs thanks for your time
Old 06-25-2009, 05:06 PM
poncho62's Avatar
Wiki Edits: 5
moving this to the steering forum
Old 06-25-2009, 06:00 PM
Wiki Edits: 31
have it alligned.. caster is likely out on 1 side
Old 06-25-2009, 10:35 PM
thank you
thanks,i will try that, hope it don't cost much.
Old 06-26-2009, 08:25 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Front end alignment costs vary, but >/= $50, here in the US in many cases.
You can check toe-in yourself, if you have access to a flat area of pavement (concrete, preferably) and a length of string. Methods vary, I've always had good results by measuring rear to front, as opposed to back of front tire compared to front of front tire- but this was because of the (lack of) ground clearance I was dealing with.
Besides alignment, you could have a bad rack or steering gear as well as possibly damaged or worn components.
If you jack this thing up to check it over, BE SURE that you use jack stands and block the rear wheels from rolling.
A couple sites w/various methods to measure toe, etc. are:
http://www.nichols.nu/tip092.htm
http://www.mth.msu.edu/~drachman/cycle/alignment.html
http://www.lotustalk.com/forums/f91/...parison-71607/
Tilt steering lever - 2000 Malibu - NOT Hotrod heyjude076 Suspension - Brakes - Steering 4 03-01-2007 11:07 AM
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 06:31 PM
Late model GM Steering Column for Model A Woody31coupe Suspension - Brakes - Steering 3 12-31-2005 05:55 AM
1932 Chevrolet Grill and Shell on 1931 Model A Ford and Hood. Fortingo Body - Exterior 1 04-27-2003 02:55 AM
best steering column for 29 Ford street rod pikalpha Suspension - Brakes - Steering 5 11-28-2001 10:54 AM
