Ford transmission sensor trouble - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-09-2010, 11:02 PM
brian12c's Avatar
My fiancee has a Ford Escort ZX2 with the f4e at transmission in it. It recently set a p0715 code for a bad TSS circuit input. Heres some ford literature I found about the operation of the sensor.
Turbine Shaft Speed (TSS) Sensor
The Turbine Shaft Speed (TSS) sensor is a magnetic pickup that sends the Powertrain Control Module (PCM) information on the rotation speed of the coast clutch cylinder assembly. The Turbine Shaft Speed (TSS) sensor is mounted externally on the top of the transmission case. The Powertrain Control Module (PCM) uses Turbine Shaft Speed (TSS) sensor signals to help determine Electronic Pressure Control (EPC) pressure, shift scheduling the Torque Converter Clutch (TCC) operation.
Mitchell says symptoms caused with this code are harsh shift engagements, which I do feel from time to time.
My question is which came first, the transmission slip or the faulty input signal? I know the faulty signal could cause harsh shifts, but could harsh shifts from the trans going out cause the faulty signal? basically I want to know if I have a bad sensor or a slipping transmission.
Thanks a bunch for any input
BF
Old 12-11-2010, 05:20 PM
LATECH's Avatar
I would have to say the sensor failure will be the cause of your trouble.
I had a 02 jetta a while back the guy drove for 2 years with the check engine light on and a harsh shift. We fixed that one with a new airflow sensor and a few other vacuum hoses and minor stuff and the trans worked perfectly after that. The guy drove it that way casue he thought the trans was going to quit so he ignored the check engine light. I would think the tss isnt very exspensive.
List all of your cars HERE! Carbed95GT Hotrodders' Lounge 289 11-09-2011 07:43 PM
1981 ford f150 300cid c-6 transmission porkchop480 Transmission - Rearend 8 10-27-2008 12:16 PM
Flathead Ford Transmission Adapter Old school kid Transmission - Rearend 3 01-24-2007 03:04 AM
T-5 Transmission To A Flathead Ford V /8 1948, Late Model DMMARTIN Introduce Yourself 3 12-06-2006 10:29 PM
Ford Probe transmission problems.... zipfactor Transmission - Rearend 3 11-27-2005 04:51 PM
