Ford V8 289, which is which - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2004, 03:58 AM
calimstng66's Avatar
*sorry for the stupid subject title couldnt think of one
how can i tell on my 1966 ford mustang which engine it is. Such as the one with 200 hp, 225hp, 271 hp.
is there a place to look or what.
Old 04-17-2004, 06:30 AM
buckethead1's Avatar
Door Tag Decoder
Old 04-17-2004, 07:55 AM
woodz428's Avatar
Troll Hunter
Arrow
If it is the original engine, an easy way is to look at it. The 200 is 2bbl, the 225 is the 4bbl and the hi-po is a 4bbl with a centrifugal distributor (no vacuum can). If you should pull a valve cover the 2 lower hp engines will look the same the hi-po will have screw in rocker studs and cast spring seats.
