Ford V8 motor mount question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2013, 08:44 AM
Old Fool's Avatar
I few days ago a guy told me that by using Camaro motor mounts and putting them on the opposite sides any Ford engine will fit in any Ford chassis. Not being a Ford man I didnt call bs, but it sure sounds like it to me.
What is the true story?
thx.
Old 03-20-2013, 11:27 AM
Wiki Edits: 27
ford to ford.
You can switch Ford FE motor mounts and bolt in a Y block etc. ford and gm are totally different.
Old 03-20-2013, 08:17 PM
Wiki Edits: 31
It's BS. A Camaro has only come with half a dozen different engines thru the years. inline 6, SBC, LT1, 60* V6, LS1 and now the newer generations have a new V6 and LS based V8 engines.. Every variation and generation change will have a different mount.
If he had said that GM mounts can often be flipped to mount other motors just like some Ford mounts can, then it would be accurate and believable
motor mount question 87fubar Hotrodding Basics 3 05-12-2011 05:23 PM
Motor mount question cyberdork Hotrodding Basics 5 03-21-2011 08:03 PM
Need motor mount for 460 Ford Ratoflic Engine 2 08-19-2008 12:15 AM
motor mount question dawg Engine 3 12-02-2007 12:10 AM
Motor mount question raidmagic Engine 6 10-23-2004 05:27 PM
