Ford van quandry - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-28-2008, 07:11 AM
Ford van quandry
A buddy of mine has been having trouble with his late 90's Ford van. It has a 302 engine. He's been having rich running problems with it (rough idle, smoking, excessive gas use) that the dealer can't seem to fix.
He's wanting to take off the injection and put on an older 302 intake and carb, using regular linkage, etc. and go back to simpler....
Can he do this? Does the computer control more than just the engine? I'm trying to help him get this thing fixed without it becoming a money pit. The engine runs decent, but has pretty many miles on it. It's just a work truck.
Thanks for the help.
Old 05-28-2008, 08:16 AM
Wiki Edits: 31
Yes and no... you could but it is not logical. The dealer can fix the problem, they have every resource to diagnose it.. there probably milking it to get more money. it sounds like a case of a bad coolent temp sensor, which is a $20-40 fix... coolent temp sensor reads cold all the time, so it never goes out of open loop, you get a rich condition, sometimes a rough idle and black smoke sometimes also.. if the smoke is blue, it's a blowby or valve stem seal issue and likely not related to the problems.
Old 05-31-2008, 09:32 AM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
I agree its not a logical solution, and it might open up a lot of new problems. Bring it to someone who knows what he's doing, get it fixed properly. The injection system on those engines is pretty good and not too hard to fix.
Old 06-01-2008, 01:09 AM
Anybody asked the computer what's wrong yet? Sometimes it'll tell you exactly what's wrong.
Old 06-01-2008, 02:22 PM
Do not Ford dealers have equipment to hook up to "talk" to the computer, and would that not be the first thing they'd do in this situation?
Old 06-01-2008, 02:37 PM
1988 Gasser style Ranger
sure you could put a non computer engine in there but its never that simple
I put a non computer v8 in a 88 ford ranger but as you are doing it a zillion little things will pop up that demand money
SOOOO
if you intend on keeping it a work truck then fix what is there
GOOD LUCK
Old 06-01-2008, 07:15 PM
How late 90s, the technology goes thru big changes at times on a yearly basis. 95 and older it's probably an OBD I system which is simpler to work with. 96 and up it's an OBD- II system which is more comprehensive but pretty much shuts the backyard mechanic out unless they're very computer system savvy. But depending upon model, you can find OBD II systems as full or partial beginning to infect designs as far back as 94. So year and model is important data.
Both systems have a lot of on-board diagnostics that can be down loaded either thru the "Check Engine Light" or to a PC with a diagnostic program loaded on it, or to a "Reader". Many better parts stores will read it out for you as they'd like to sell you parts so they'll do some diagnostics for you. If the problem is sensor related, the computer should have set the "Check Engine Light" which tells you for sure the computer knows something isn't right and will point at some link in the chain of sensors, it isn't always the one at fault, but it'll be in that logic chain.
Rich running can be the temp sensor, which is separate from your gauge sensor, is off and is keeping the engine in warm up mode although I'd be surprised that cold start is so rich that you're gagging on the exhaust. Vacuum leaks into the intake and even exhaust leaks will mess with several sensors including the O2. If it even thinks the engine is lean, the signal to the computer will cause it to richen the mixture. A failed pressure regulator or plugged bypass ,if used on his model, can increase system fuel pressure which will always over fuel the engine. In fact this would be one of the first things I'd look for because this can drive the mixture so rich the smell in the exhaust is going to be really bad. Other related problems can be a failed or out of synch vacuum transducer, this is reading manifold pressure, which the computer uses along with throttle position sensing and if so equipped a Mass Air Flow (MAF) sensor to determine the fuel and ignition advance values. Problems can also be from simply bad connections or voltage problems that are too high, too low, or wander because of battery, regulator or alternator problems.
So while everybody wants to immediately go to the computer and the expensive stuff, take the time to look for bad vacuum hoses, leaks in the exhaust ahead of the O2 sensor, bad wiring connections, over or under volt conditions in the electrical system before throwing expensive parts at it. Check the fuel pressure, then go to sensors. Just start simple, especially if it isn't throwing codes. If there's no error codes, it's a fairly good sign that the problem isn't a sensor or wiring between them and the computer except for maybe a physical adjustment which some sensors require like the throttle position sensor for alignment, but rather some old fashion problem like a leaking vacuum hose or a blown head gasket. Things like that change the values the sensors are looking for and when they get out of whack with what they're expecting to see or out of synch with each other, the computer gets confused and like HAL, does the best it can to handle conflicting commands. So while it may put you on the side of the highway at least it won't put you into the cold of inter planetary space without life support.
To convert back to a carb presents a sizeable effort as the computer runs the transmission, the instruments, anti skid, anti theft, etc. It needs inputs from the engine sensors to do this, so just pulling connector plugs isn't going to get ya there.
Bogie
Last edited by BogiesAnnex1; 06-01-2008 at 07:22 PM. Reason: really crummy sentence structure
Old 06-01-2008, 07:27 PM
Wiki Edits: 31
pre '96 Ford is EEC IV, very easy to work with. there is a way to set jumpers on the connector to flash the code thru the CEL as bogie said..
Old 06-27-2008, 07:18 AM
A buddy of mine has been having trouble with his late 90's Ford van. It has a 302 engine. He's been having rich running problems with it (rough idle, smoking, excessive gas use) that the dealer can't seem to fix.......
This sounds like a faulty O2 sensor to me. It's an easy fix, and cheap (Under $50). Might also be a broken sensor wire.
Regardless, that particular dealer isn't worth beans......
All right all you Ford guys, a couple of questions Shades_o_Grey General Rodding Tech 8 12-28-2010 06:00 PM
'85 Ford Van: AmericanPackMule Engine 1 02-11-2008 06:38 PM
Ford Muscle..what's wrong with them? tm454 Hotrodders' Lounge 41 11-20-2006 12:37 PM
Explorer Disc Bbrakes on a 9" Ford Rear End Mustangsaly Suspension - Brakes - Steering 2 10-31-2005 04:18 PM
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 05:29 AM
