Ford wagon tailgate lock dosen't work
1984 Country Squire wagon's tailgate lock won't lock. Power and manual operate the lock fine just will not lock. I'm stumped, help.
Latch and opening and closing work fine. Glass goes up and down also. It just won't lock manualy or by key
tailgate
Bob |
Not an uncommon problem with Fords - including their p/u trucks with a locking tailgate - even my '06 F350 needed some TLC as early as a year or so old. (and so did my '79 wagon, my '97 and '01 trucks)
You have to take the inner panel off, clean up any corrosion, grease it up (I like silicone grease) then reassemble. Sometimes you will have to change out the lock mechanism if the pot metal is crusty and dissolving, but that is also easy. The major problem being another key just for that lock |
Thanks for the info
tailgate
Bob |
Any latch of this vintage works on a pretty simple principle. There is one (#1) piece in the latch that moves up and down or side to side and this one piece simply stops the movement of another piece (#2) which locks the latch.
I know this sound obvious but that if you remove that latch you will see what I am talking about. When something like this happens #1 is usually not moving as it should. Be it an actuator rod from the lock cylinder has fallen off or #1 is not moving freely because of 52 year old grease has turned to a hard wax like state or there is wear on that piece so it isn't moving something as far as it could. Take the inner panel off and see what you find. Brian |
| My homemade tailgate for the 47 ford | hotwheels1 | Body - Exterior | 6 | 10-11-2010 02:59 PM |
| tailgate work ????? Photos.. | dar130 | Body - Exterior | 1 | 07-14-2008 08:52 PM |
| Tailgate for 35 Ford pickup? | Kruzin Karl | Body - Exterior | 2 | 03-02-2006 06:27 PM |
| 63 nova wagon tailgate power window | 63novawagon | Interior | 4 | 06-30-2004 08:02 AM |
| Will a 1941 1/2 T P/U Tailgate fit on a 1945 ford 1/2 t p/u | biglee550 | Suspension - Brakes - Steering | 2 | 06-11-2004 09:03 PM |
