FORD Water pump outlets - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-20-2012, 08:14 PM
65ELCMO's Avatar
302 Ford waterpump has two outlets. One goes to the thermostat housing. Does this pump water into the manifold? The other one is for the heater. Is this pressure or suction?
Old 02-21-2012, 05:56 AM
bondo's Avatar
Ayuh,... The Outlets push water into the block...
The hose from the T-stat, I believe is just a T-stat by-pass...
And, the other hose is coming From the heater...
Old 02-21-2012, 07:30 AM
The heater hose to the water pump is the return hose.
Ford V10 Water Pump Removal ricksautorestoration Engine 6 11-16-2010 06:05 PM
Water pump outlets/inlets muddi1 Engine 3 08-21-2010 11:50 AM
Ford water pump rotation 1953 Homer Engine 58 01-04-2009 04:00 PM
Edelbrock Air-Gap Water Outlets syborg3D Engine 1 05-18-2006 03:22 PM
power steering from long water pump to short water pump kellyem Suspension - Brakes - Steering 7 02-22-2004 07:22 PM
