Ford Windstar engine interchange - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-03-2008, 03:12 PM
Ford Windstar engine interchange - will 2003 3.8 fit 2000 3.8?
Need to replace the 3.8l engine in my 2000 Ford Windstar. Can purchase a low mileage 3.8l engine out of a 2003 Windstar. The Hollander interchange does not show the '03 as a replacement for the 2000, but it looks identical. The salvage yards I have contacted just look at the interchange books & say it will not fit. I know sometimes engines need the intake or exhaust manifold replaced or other adds ons switched to work on other years - but I could not find much info available on the Windstar 3.8l switch? Any info is appreciated - Thanks
Old 10-03-2008, 03:21 PM
FEDDO's Avatar
google windstar.
Old 10-03-2008, 03:35 PM
Wiki Edits: 31
the electronics are diffrent. if you transfer everything off your engine onto the 2003 engine, it will work. I'v done a trans on a '97.. it will be easiest for you to drop the cradle to get to the motor.
Old 10-05-2008, 07:24 AM
Windstar eng swap
We have a 2002. As indicated previously I believe this will work if you swap all your non-short block parts to the new engine. I would contact Ford to verify the short blocks are the same and the non short block items are interchangable.
Good luck with this, sounds like a bear to swap engines on this platform.
Roy
Old 10-05-2008, 08:16 AM
Change out
Thanks for the information, I have access to a 2002 engine also< i Wonder if the same problem still exsist?
1968-1969 olds 455 engine is this good and how can i id 1968olds455HO Engine 5 09-02-2009 11:53 AM
SF oil???? n-gin Engine 6 07-09-2008 01:37 PM
An old Ford engine. What is it? bb53chevpro Engine 12 09-08-2006 08:48 AM
ford engine questions jezlearnin01 Engine 15 04-14-2006 05:58 AM
Ford engine... JohnyR17 Engine 3 01-25-2006 10:51 PM
