ford wire wheels - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2006, 10:34 PM
1929 ford tudor
ford wire wheels
I came across a set of what i think are early ford wire wheels. The lug pattern is 5 on 5"(16" tire), I thought that 28-48 cars were all 5 on 5.5"? could these not be fords?
Old 09-15-2006, 12:46 AM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
28-48 Ford cars were all 5 on 5.5 inches. Could be a set of wheels from an early GM product or probably a whole lot of other makers. Seeing as they are 16" rims they would come from the mid 30's. Model A's came with 21 and 19 inch rims. Post some pics and maybe we can help you out.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 09-16-2006, 03:09 PM
1929 ford tudor
??wire wheels
Here are some pics of the wheels.
ID:	14953   Click image for larger version
Old 09-18-2006, 08:04 AM
Last journal entry: Lessons learned, how to's, etc...
Those are Ford centercaps, but the wheels don't appear to be Ford. Ford had welded spokes whereas your's screw into the rim.
Old 09-18-2006, 11:00 AM
powerrodsmike's Avatar
Wiki Edits: 161
Homebrew- 36-39 fords used the wide five pattern.
Here is a spiffy thread by wheelkid with some pics
Early Ford Wire Wheel Tech
There are some pics of aftermarket wheels of that era in that thread.
I'll bet a PM to wheelkid asking for some help is in order
Later, mikey
BE different....ACT normal.
Old 09-19-2006, 12:40 AM
home brew's Avatar
You are right!
redsin - Are you sure that you are measuring that bolt circle pattern correctly?
Old 09-19-2006, 01:17 AM
wheelkid's Avatar
I think those are some kind of plymoth wheel, let me do some research (ask my dad when he wakes up) and I'll have a more definate answer for you in the morning, Definatly not a ford wheel
Jimmy
Old 09-19-2006, 10:00 PM
wheelkid's Avatar
I talked to my dad, and he says you must have measured wrong. He says its an 18" Motor wheel. An aftermarket thing for fords. The bolt pattern is 5 on 5.5
Old 09-19-2006, 10:11 PM
home brew's Avatar
I wonder how they got those 16" tires on that 18" wheel?
Old 09-19-2006, 10:30 PM
Wiki Edits: 161
Lots of rubber lube
Hey wheelkid- did you misread something???
Mikey
Old 09-19-2006, 11:14 PM
home brew's Avatar
I thought that you used rubber lube for something else.
Old 09-19-2006, 11:39 PM
1929 ford tudor
ford wire wheels
Here is a shot of the measurements measured from the outside of one hole to the middle of the third hole. 5" 17"rim
Old 09-19-2006, 11:52 PM
Wiki Edits: 161
Having materials that can be used for multiple purposes cuts down on storage, inventory and confusion when choosing the right stuff for a given job.
I use the same stuff for putting tires on, drilling, tapping, lubing up my rubber shirt so's I can get it on before a big rock show, parting on the lathe, cleaning grease off my windshield, bug repellant, bringing back that factory fresh shine to my shovelhead, keepin my hair from being all wild between haircuts and at lunch time it makes a super dressing for my taco. Oh, and it drives women crazy.
Make it a part of YOUR tool kit
Later, mikey
Old 09-19-2006, 11:55 PM
wheelkid's Avatar
I could have sworn it said 6.00-18 on the tire. Are you guys sure it doesn't?
Old 09-20-2006, 12:00 AM
1929 ford tudor
ford wire wheels
6.00-16 looks like 18 in that pic.
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 07:31 PM
1 wire alternators.... Crazy Mopar Guy Electrical 36 04-09-2006 07:37 PM
Henry Ford in Heaven schnitz Hotrodders' Lounge 9 10-19-2004 11:09 AM
Mopar vs Ford wheels SoCalRoddin' Suspension - Brakes - Steering 3 10-13-2004 02:19 PM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 10:20 AM
