ford-y-block - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2008, 02:11 PM
ford-y-block
On ford-y-blocks everyone connects one heater hose to the water pump and the other to the water jacket on the intake manifold. The moters manual shows both connected to the water pump. Why?
Old 10-29-2008, 02:25 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Moving to the Engine forum
Old 10-29-2008, 02:26 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Welcome aboard the board.. This is just the intro forum and you will have better luck if you post in one of the tech forums..Welcome
Sam
Old 10-29-2008, 02:46 PM
powerrodsmike's Avatar
Wiki Edits: 161
You won't get much flow to the heater if you connect both hoses to the water pump. The water pump pulls water in from the bottom of the radiator, and the heater core. The hot water for the heater flows from the hottest part of the motor, at the intake manifold crossover , through the heater core, then gets pulled into the water pump.
I looked in a 1957 motor's manual, and couldn't find the picture you reference, but I looked in a ford factory manual from a 64 pickup, (uses a 292 Y block), and see that one hose comes from the water crossover in the manifold, goes through the hot water control valve, then to the lower heater core fitting. The upper hose from the heater core gets returned to the water pump.
Later, mikey
BE different....ACT normal.
ford y block customjustin Engine 5 01-30-2008 10:15 PM
Ford Y Block Engine RetroJim Engine 11 06-14-2006 06:37 PM
Why is the Ford 302 block better than the 351W? BarbWire Engine 63 06-01-2006 05:35 PM
standard trans to ford big block lover_of_fords Transmission - Rearend 3 04-24-2003 07:17 PM
Big Block/Small Block - Ford BigBlockBabe Engine 12 11-10-2002 04:01 PM
