Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - ford y block
Thread: ford y block
Old 05-01-2013, 03:26 PM
cliff tate cliff tate is offline
yblock headsb
[QUOTE=painted jester;1671621]Haven't worked on y blocks in a few years, and only know of a couple of guys racing them and 1 runs iron heads, the other Mummert's aluminum. That's a lot of money for just a few HP and an extra jump in rpm!!!!! Unless you are laying out the bucks for the Cam, Pistons, Rods, Crank, Balancing ,Etc,Etc to use the heads to their potential! Then they would be a good choice!! But if your basically building a street engine for street performance I would think twice. They are pretty though!! Lets see a pic of that 292 What cam and induction you planning?
Jester
Check out this:
Eaton Balancing Ford Y-Block Aluminum Head Testing Part I
Eaton Balancing Ford Y-Block Aluminum Head Testing Part II
thanks for the info,i have 030 over 292 with ecz g heads stock 57 4v cam with stock 4v manifold and holley 600 carb.my plans ar to build a stronger y in the future,car is a 57 ranchero ,3spd manual,spoke with a guy at a show who had the heads on a 292 and he was impresed,just looking for some opin. from other. ap the help cliff
