Ford y block 4 speed trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2006, 07:09 PM
I would like some help . I would like to put a 4 speed trans to my Y block 292 . Can this be done ? If so what trans and bell housing do I use ?
What year bell housing and which trans and year will be best ? I am going to Carsile , Pa in early June for the All Ford Show and look for some parts there , maybe .
Thanks,
Jim
Old 05-25-2006, 07:25 PM
redlightning's Avatar
http://www.y-blocksforever.com/phpbb...pic.php?t=1981
Above is a link with some info.
Old 05-26-2006, 03:44 PM
Thank you for the link !! I will check to see what that has to say .
Jim
Old 05-26-2006, 04:59 PM
aka Duke of URL
Should present little problem. Used to be a popular retrofit on 55/57 FORDS. Either a BW T10 or the F/4/S.
Why is the Ford 302 block better than the 351W? BarbWire Engine 63 06-01-2006 05:35 PM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 12:48 PM
Track Car Overheating, small block Ford RAW Engine 15 12-16-2003 10:25 PM
standard trans to ford big block lover_of_fords Transmission - Rearend 3 04-24-2003 07:17 PM
Big Block/Small Block - Ford BigBlockBabe Engine 12 11-10-2002 04:01 PM
