fords - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2006, 10:33 PM
fords
having trouble with a clutch slave cylinder. have tried to bleed, and still not moving? getting fluid out, but no movement. brand new fly,and clutch kit, with slave. pulling out my hair and getting anywhere. HELP.
Old 09-17-2006, 07:37 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Are you working on a 1979 Escort with a 2.3 engine, 5 speed trans axle?
they are trouble
Old 09-17-2006, 09:13 AM
machinist & fabricator
do you have a pull or a push type slave?
Old 09-17-2006, 10:16 AM
its a pull
its a pull design, 93 ford explorer 3.0l 4wd
Old 09-17-2006, 11:09 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
OIC.......I see the slave cyl was replaced, was the master cyl for the clutch replaced too?
Old 09-17-2006, 11:27 AM
reply
negitive the clutch fraged out so as long as i was in there i replaced the kit and slave. i have no pedal and no movement from the slave. i do get clean fluid from the slave, but no preasure behimd the pedal.
Old 09-18-2006, 10:27 AM
nitro_baller4692's Avatar
floppers forever
how are you trying to bleed it?
Old 09-18-2006, 07:44 PM
somthing new
trying a power bleeder for a tranny shop and i've gone thru 5 qts of fluid in the first pass. i can now get it in gear with the engine off, but when the shifter is close to a gear wiht out being in gear the tranny wants to go. with no change if the clutch is in or not!? i must be doing somthing wrong. should the engine be running, or off? should the clutch pedal be in or out? really lost,
Leg room in early 30s Chevy & Fords? 54 Chevy Hotrodders' Lounge 3 11-19-2010 06:57 PM
Chev's are better than Fords Iroc'o Hotrodders' Lounge 38 06-16-2004 09:09 AM
Looking for web sites for 40 fords CTSmokey Hotrodding Basics 3 03-07-2004 06:40 AM
Fuel Cells for early Fords Lee Hulick Body - Exterior 0 05-24-2003 06:11 PM
How desirable are 1950 Fords?? Good deal? '54-Hunter Hotrodders' Lounge 7 02-08-2003 07:51 AM
