Yes, cast would work, for a while, I would look for a forged crank.
Same goes for hypers vs. forged. Yes, you can use a roller cam, you just need retrofit lifters. |
What kind of budget do you have for cylinder heads?
Are you planning on running on pump gas or race gas, ethanol, what type of fuel? 500 HP 383 on pump gas probably won't happen, but if you're looking at race gas it can happen. |
well i want for it to run on pump gas if i can get 450hp+ i would be more than happy
there 190cc 64 combustion chamber 2.02intake and 1.6exhaust valves and for the cam i was looking into comp cams part number: Xtreme Energy XR282HR and for a carburator i checking out the edelbrock 750cfm manual carb and a steel cast crankshaft 3.75 stroke hypereutectic flat top pistons 4.040 will this be a good combo to make those kind of hp 450-520??? |
I believe the Scat and Eagle cast cranks are rated up to 500 hp. Sounds like you want "at least" 500 hp. If you have the money, might as well go forged.
Use a retrofit roller camshaft. Hypers should be fine. If you want 500 hp out of your 383 and want to run pump gas, look into a set of 195 cc AFR heads. Check out the 383 503 hp combo at the top of this link. http://www.airflowresearch.com/chevy_dyno.php With those heads, 9.5:1 CR, and comp cams #12-433-8, you can reach your goal. http://www.summitracing.com/parts/CCA-12-433-8/ I hope this helps. |
With proper heads and either a different intake or a lot of work done to that one you can easily hit 500hp on pump gas... But you'll lose some driveability.
The cam should be your last decision, not one of your first. After you have everything else bought, measured, and assembled, then contact a good well known cam grinder and have a cam ground to match your parameters and engine. If you want the most power possible then you need to forget picking your cam yourself and have a pro custom grind one for you. The cost is only an extra $50-$100 and the power difference can be very significant. Things you will need for an easy 500hp: 900+cfm carb 1 3/4" long tube headers 200cc-ish heads that flow 260+ cfm ported RPM intake or super vic intake (or equivalent) 10:1 compression Tips that will help you along the way- if you run on the small side (195cc) of cylinder head port volume i use long rods (6") if you run on the large side (215cc) then use short rods (5.7") DO NOT CHEAP OUT ON VALVE TRAIN Really, anytime you cut a corner just think of it as dropping 20hp off your potential- if you use a slightly mismatched carb, headers, and intake your looking at loosing 60 or so hp- your 500 just became 440ish. Don't forget your drivetrain will need to be able to handle 500hp as well... So take your engine cost and double it to equal project cost. |
i want to run between 1500-6500rpm
i already have the: 1 3/4" long tube headers and my goal was to hit atleast 10:1 compression with flatop pistons so would an edelbrock 750cfm carb be ok for 500hp??? also i have a choice on transmission i have 2 fully build for racing one is a th350 fully build with a 9" dacco torque converter with a 2,800+ stall and a 700r4 with a 12" b&m torque converter with a 2,300-2,500 stall |
My combo that was ran on a simulator
Dude,
This is the combo i'm going with that was put thru a Sim. 383 3.750" Crank 5.7" Big beam rods 10:1 Comp. Dart 200cc Int. runners 2.02/1.60 Iron heads (Platinum Iron Eagles) CAM, .533" Int. and .555" ex. valve lift. Advertised duration is 288 Int. and 294 ex. Duration at .050" is 236 Int. and 242 ex. Ground on a 110 Lobe center. (Comp Cams juice roller 08-433-8) 1.6 rocker arms EdelBrock RPM Air Gap 750 street HP doublepumper Here are the results RPM HP TQ 2000 136 358 2500 173 363 3000 220 386 3500 287 431 4000 356 467 4500 417 487 5000 469 493 5500 502 479 6000 512 448 6500 508 410 In afghanistan now..dropping this in my 66 Caprice when I get home.
And more than likely, neither stall will be sufficient for a 500hp 383. |
That does nothing for the flow of air... There's nothing wrong with cutting corners, just don't expect it to be just as good as if you didn't. There are a lot of people running around with nice 425hp-ish engines that were built in their garage using cheap parts, and they still run fine and do what they need done... And then there are engines that are built with performance as the number 1 goal while cost takes a back seat. I build more of the first type as I have other things to spend money on, but I am aware of the difference. |
really my goal is to run an 11 high or mid 11 on a 3rd gen t/a gta money is a lil hard am also working on my 99 trans am ls1 have a couple of bolt ons just need a custom tune also am working on my 86 camaro z28 and c10 lol thats why am using the cheap parts
| 350 vs 383 build for performance | Biscuit6447 | Hotrodding Basics | 20 | 03-05-2010 08:42 AM |
| Chevy 383 What cam to run???? Also Forged or hyper pistons?? | 89SDime | Engine | 19 | 02-27-2006 11:59 PM |
| Best all-in-one 383 kit with forged pistons? | Lynx_TWO | Engine | 6 | 02-06-2006 06:57 PM |
| 383 Stroker Build! Hypereutectic or forged aluminum pistons????? | 89SDime | Engine | 12 | 09-08-2005 07:08 AM |
| .60 over 383 SBC Questions | Mustangsaly | Engine | 8 | 06-28-2005 12:18 PM |
