Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - forged block
Thread: forged block
Old 02-27-2012, 09:39 PM
Blazin72's Avatar
Blazin72 Blazin72 is offline
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
The best thing you can do is set a realistic goal of what you are looking for here then ask questions that pertain to that goal. It's pretty safe to say that at 17 you aren't going to get 515hp to the rear wheels on your budget so just forget about that one. 350 to 400hp+ is easily doable with a 383 and the best thing you can do is use that big white search bar at the top of each page and read similar threads and questions that have already been asked. Probably the two most common engines talked about on here are 350s and 383s. There is more than enough information to answer almost any question you will probably come up with. It just takes time to read it. If you can't find the information you are looking for then by all means, ask.
