Forged Rods and Pistons for Ford 302?
I have a basically stock 1969, Ford Mustang 302 cid. It has it's orginal motor. I have changed it's rings recently leaving it with a .030" oversize. I used the original pistons and rods. After a visual inspection the components seem to be rather sound. I have been in possesion of the car for almost a year, and have no idea how they treated it before me, but apparently it was not too punished. My plan however is to change some components to have a more high performance orientated setup.
I eventually plan to use nitrous. They have recommended me to change my pistons to forged ones, which is obvious, and also the connecting rods however I am not too certain of this last recomendation, what do you reccomend I do. I do not have an endless budget, although I know that you can't have any thing good cheap, I want best value for money, and not to over spend on an aplication that I will not be using to it's full extent. The use would be mainly high performance street and some drag racing. There is a larger availability and selection of pistons than of rods so from what I can gather
As far as I have learned it is necessary, if not essential, to change my pistons to be able to withstand the increased loads, however I have not been able to gather much information as to what I should do concerning the connecting rods.
Concerning the pistons, I understand the my car came with a stock compression ratio o 9.5:1. To increase performance I undestrand that it is good to increase this compression ratio, however, if I use nitrous this may not be recomenadable, what is your opinion?
I have headers installed and plan to change: air manifold, 700 cfm 4 barrel carb, camshaft, heads... I do not want to stroke the engine. I reckon I should end up with a little over 350 hp without nitrous.
In conclusion how advisable is it to change the connecting rods, is it really worth the effort and what pistons are recomendable for my application.
For more details concerning my car please visit my site: <a href="http://www.kovacic.tie.cl/mustang69/" target="_blank">http://www.kovacic.tie.cl/mustang69/</A> the links on top frame or bar "Model of my car" has my VIN plate information and "Modifications" has what I have done so far and what I plan to do.
I'd be really grateful for any advice on this.
