forged short block - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2008, 06:28 PM
forged short block
I have been looking for a forged bottom end to build from with the end result of a weiand 144 sitting on top . I already have the blower and manifold , I will reuse the 4150 750cfm carb and headers from my excisting motor .
Is anyone familiar with Blue print ? I was looking at this
http://www.jegs.com/webapp/wcs/store...0002_834053_-1
Any more suggestions ?
Old 02-13-2008, 07:10 PM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
That would be a good base for your setup, but with flat top pistons you will need large combustion chambers to keep your compression low enough to run 6-9 psi of boost.
So if you purchase aftermarket heads you should get some with 76cc chambers if you want to avoid detonation.
Old 02-13-2008, 07:23 PM
streetrodderbn's Avatar
Certifiable Streetrodder
you don't necessarily need large chamber heads,I built a 30 model a dlx.roadster that was a feature in street rod action, that I owned for 13 years, I ran a +.030 350 chevy with pink rods,a factory steel crank,and forged t.r.w. 7.5:1 compression ratio reversed dome(d-shaped) blower pistons i had the rotating assembly balanced, ran a b+m megacharger camshaft with crower roller rockers and brodix track 1 aluminum heads, a rossler racing transmission street/strip 350 turbo transmission with a 2800 t.c.i. converter with anti-balooning plate, and a 4.11 posi 8 in. ford with 29.1 tall 8in. wide steel wheels with wide white radials. I ran 5,000 miles worth of regular pump gas through the engine with no detonation( I had a vacuum boost retard g.m.h.e.i. dist.recurved as to my specifications) and it ran flawlessly, with absolutely no problems,other than the need to make a stop for the windshield so it could not swivel in to hit your hands during extreme acceleration!! ( i was running a b+m forced induction -144-supercharger)
Old 02-13-2008, 07:31 PM
techinspector1's Avatar
Wiki Edits: 326
Agree with Double_v23. Look at this chart from Blower Drive Service. Scroll down to the chart titled Blower Boost. It shows the relationship of static compression ratio to boost with pump gas (dark gray shaded numbers) and good gas (light gray shaded numbers).
http://www.blowerdriveservice.com/techcharts.php
Old 02-13-2008, 07:34 PM
Wiki Edits: 326
I think Double was sayin' that if he goes with flat-tops, then he's gonna have to lower the c.r. in one fashion or another and large heads would be the logical step.
do it right the 1st time, strong 400 short block budget build, stock parts? Warrant Engine 9 12-04-2006 08:29 PM
What can a properly prepped stock 5.7 chevy rod handle? 400 short block build for Warrant Engine 0 11-23-2006 09:21 PM
need advice, short block build up Blob Engine 8 12-09-2003 07:58 AM
ID on Ford short block billybob_v10 Engine 7 10-04-2003 01:50 AM
Hard Block Short Fill reddwarf Engine 1 03-30-2002 06:42 PM
