Forged steel or cast crank? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-20-2002, 02:08 PM
Post Forged steel or cast crank?
Is the crank on a '69 Dodge 383 truck going to be forged steel or cast? Will it be swappable with a 440 crank?
[ December 20, 2002: Message edited by: MopaRV ]</p>
Old 12-20-2002, 04:33 PM
Post
If this is the original 1969 383 mopar it should be a forged crank. Mopar used forged cranks up to about 1974. A 440 crank will not fit in your 383. the 440 engine is a "RB" which stands for raised block. The 440 has a higher deck clearance. they are both big blocks but they are not the same. 440 and 383 manifolds also do not interchange.
