Forgot to prelube front pump! is it a problem? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-30-2005, 03:25 PM
I rebuilt a TH 350 but forgot to prelube the front pump. It is now in the car, if I put in 8 qts of ATF and crank on the engine and then let it sit for alwhile will enough fluid get in the pump. Enough to lube it and self prime itself to pump fluid without causing damage. I did remember to put about 2 qts in the new converter.
Thanks Jeff
Old 07-02-2005, 05:43 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Should be fine.
Old 07-02-2005, 09:02 PM
Yep, you were correct it appears to be just fine.
dana 44 front axle non hotrod problem. crazy larry Transmission - Rearend 16 04-19-2005 01:47 AM
Heater, wiper fluid pump problem trenchdog73 Electrical 1 02-26-2005 04:54 AM
Power Steering Pump Problem... IWasBlown Engine 1 04-07-2003 09:03 PM
please help..... annoying warm start problem 67cuda Engine 21 03-28-2003 05:44 AM
Fuel / Carb problem DoubleVision Engine 5 10-28-2002 05:18 PM
