forgot thread seal on manifold - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2009, 03:22 PM
Another thread reminded me I had forgot thread sealant on the manifold bolts. this is a victor jr manifold mating to Aluminum heads and GM 3970010 block; with arp stainless bolts. gaskets are felpro with the silicon beads, plus some orange rtv I put on myself. I did an otherwise good job...
Is it a bad idea to unscrew the bolts and leave the manifold on? Either by taking one bolt out, sealant it, then put it back in, or take them all out gently, slap the sealant on and screw them back in the correct order? either way it seems like it might disturb the gaskets, sorta like head gaskets that only like to be torqued once...what would you do? thanks
Old 06-13-2009, 03:31 PM
fast68's Avatar
likes chevy trucks & boobies
i always use plumbers pipe thread dope on head bolts and sometimes intake bolts
not a huge deal on intakes but on the v-8s and 4.3L and such oil does like to travel up the intake blts andpuddle on the intake
but not always
you could pull each one and do it and be ok on most engines
only the middle ones do it, the outer end ones are in blind dry holes on most engines.
good luck
Old 06-13-2009, 03:42 PM
ericnova72's Avatar
More for Less Racer
Like Fast68 said, just pull and seal one at a time and you will have no problems.
Oil leak from balancer seal Oldphart Engine 5 02-02-2009 04:51 PM
Need accessory info for 350 SBC 1 Piece rear seal eric32 Hotrodding Basics 3 01-29-2009 06:30 PM
Help me seal a cracked intake manifold. oldguy829 Engine 22 02-28-2007 07:40 PM
Where is manifold vacuum port on Quadrajet 4mv? dr-data Engine 10 12-13-2005 04:41 PM
intake manifold will not seal oldnable Engine 4 08-31-2005 10:30 PM
