Form tubing into odd or difficult shapes. - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-19-2010, 08:54 AM
cboy's Avatar
Last journal entry: Finished
I saw this earlier today and just had to pass it along. I had never seen this technique used before to form tubing into nice flowing lines and contours. The guy doing it, Rod Rogers, is actually an upholsterer and he is building a console here...but the technique could be used anywhere, for interiors, coach building, fender construction etc etc. I thought it was pretty ingenious.
He basically cuts the metal tubing into small pieces and then slides a length of hose inside to hold everything in place while he tack welds it up. Here are a few shots of the technique. I believe he slides the hose out of the tube before all the final welding but I've got an email into him to find out that part of the process for certain.
Always learning...and sharing what I've learned.
Old 01-19-2010, 09:13 AM
cboy's Avatar
Just heard from Rod and here's a little more follow up on the technique. He does, in fact, leave the hose inside the tubing when he welds it up...and he reports no fires or problems with it.
Also, just for clarification, the tube frame he is building in these pictures will become a buck for shaping an aluminum skin...which will become the actual console. Once formed, the aluminum will be self supporting and the tube form will then be removed and not used as a part of the finished console.
But I can envision so many applications for this method...whether you leave the tubing in as support or remove it later after forming your metal (or fiberglass) around it.
Old 01-19-2010, 09:49 AM
That looks like a pretty good idea! I want to shape the back of my box on my effie to accept a tailgate off of a nomad or stationwagon of some sort. (not sure what will flow the with the rear fenders yet) I will have to try this method and let everyone know how it turns out. Thanks alot for the info.
Old 01-19-2010, 09:56 AM
Wiki Edits: 27
compound bends
looks like a good way to do compound bends. When my son was an apprentice electrician he used to complain that a lot of the journeyman who made twice as much as he did always had him do any conduit that had more than one bend.
Old 01-19-2010, 01:14 PM
cboy's Avatar
Here is a link to Rod's thread over at Upholsterer Magazine Online showing this interior build.
Old 01-19-2010, 03:10 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
That IS slick! I'm envisioning using radiator hose or hose from HDepot to do a set of headers like that... Seems like it might work.
