formula nose peice? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-22-2008, 10:28 AM
formula nose peice?
hi i have a 77 formula and it has a rubber type of nose and it has spider cracks every where from being moved around ..well how do we take the paint off, or whats the best way. i tryed tosandblast a little peice and it seemed to be too courseand it seemed to accually make the speder cracks form in the rubber.. so i went out and bought som lime to try and blast it..i have not tryed that yet..are there any othere ways to rid my nose of paint? thanks mark
Old 08-22-2008, 04:18 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Paint stripper and it would be preferable to have the nose piece off of the car when using that stuff..Once it is clean then use an adhesion promoter on it to be sure the new paint sticks..
Sam
Old 08-24-2008, 07:01 PM
thanks that was what most peole were saying. oh and i have my car apart well the front end is and i already have most of the front body peices done.thanks mark
Old 08-24-2008, 09:47 PM
You might try to soda blast it. I did my 51 F1 and it takes paint off but won't hurt chrome or glass (not that I have the glass in it I tried a scrap piece to see what it would do) so I doubt it would hurt the endura front end.
Old 08-24-2008, 10:16 PM
Don't use paint stripper on urethane bumpers, they swell up and it can cause some major adhesion problems.
Call your local Keystone dealer and see if their bumper remanufacturing department can media blast it for you. You can also have the repair and primer it. The best primer I've found for these old urethane covers is SPI epoxy, after the repairs are completed I scrub the part down with a grey scotchbrite and Ajax cleanser wet, rinse well and then clean with SPI waterborne wax and grease remover. The adhesion is unbelievable and the epoxy stays flexible.
1980 Camaro Replacing both Front end finders, before I start help needed... Juicer Body - Exterior 8 01-14-2008 07:48 PM
Ever break the starter nose?? TurboS10 Engine 29 05-26-2005 04:38 PM
engine timing: formula onecoomofo Engine 1 04-01-2004 08:35 AM
two peice driveshaft rules KLRS10 Transmission - Rearend 4 03-14-2004 03:02 PM
1968 GTO NOSE PIECE. NEED HELP!! clutter_1968GTO Body - Exterior 0 05-28-2003 05:27 AM
