Forney arc torch.
I bought this at the same farm auction that I bought my arc welder a number of years ago. I haven't used it but I thought I might see if it is any use to spot weld sheet metal together. Has anybody ever used one of these?
If my memory serves me right, that is more of a heating torch than a spot welder. when plugged into the welding machine the two carbon rods are turned toward each other to create an arc. It should be a very bright arc and produce a lot of heat. It may be possible to spot weld with it, if the amperage was turned very low, but I think it was designed more to heat metal than to do any welding with it.
I guess that explains the name, Forney Arc Torch. I wonder what the practical applications would be for this tool? I'm thinking that the heat from this would be harder to control than a gas torch.
They work well when welding or should I say brazing and trimming cast iron. When welding steel, the carbon rods do add carbon to the base metal making the welds hard and prone to cracking. The one I have has not seen the light of day for 40 years. Company gave it to me cause it just wasn't a viable welding tool. The reality of it is, it will make a neat conversation maker while hanging on the wall with little usability.
Open your own drive-inn theatre, use it for the light for the film!
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain |
| Recent Garage - Tools posts with photos |
| Vertical Welding | JohnBrayan | Hotrodding Basics | 12 | 10-18-2009 10:01 AM |
| "Basic of Basics" Welding - How do I repair body panels? | Centerline | Body - Exterior | 29 | 06-18-2009 06:54 AM |
| welder reccomendations? | rally4x4racer | Garage - Tools | 32 | 10-14-2008 09:00 PM |
| plasma cutter | Holder350 | Garage - Tools | 13 | 10-30-2007 09:07 AM |
| Henrob(sp?) and jewler's torch users | baddbob | Body - Exterior | 9 | 12-06-2005 04:16 PM |
