Forward lunge in park when starting engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-28-2010, 09:33 PM
HawkZ28's Avatar
I know Victoria's secret....
I've noticed this issue on 3 of our 4 vehicles (the 3 with 4L60E/700r4 of course).
When I go to start any of them and they're stone cold, sometimes I get a lunge while in park as the engine starts. Not a huge one that would spill your coffee, but enough that you notice it- almost as if someone is behind your car giving it a good shove to unstick you from snow.
Is this a precursor to major work, or just part of a cold transmission?
Old 11-28-2010, 11:02 PM
sqzbox's Avatar
My pipes are my music
My 03 GP does the same thing. In park, hit the key, engine starts, and the car moves forward 2-3". I just figured it's normal on the first start of the day. Been doing it since new and have 110,000 mi on it. Never been a problem to this point.
Old 11-29-2010, 04:45 AM
tnsmith10's Avatar
when will it rain???
it is normal, as there is a tsb on it.
Old 11-29-2010, 10:11 AM
HawkZ28's Avatar
THANKS!
You don't happen to have a number for the TSB or a link to it by chance?
I'm curious as to why it happens, and what fixes, if any there are.
Old 11-29-2010, 10:48 AM
tnsmith10's Avatar
Originally Posted by HawkZ28
THANKS!
the tsb is: 08-07-30-026. there is no fix as this is typical among the majority of the automatic trans manufacturers.
here is a copy and paste from alldata about the bulletin.
Bulletin No.: 08-07-30-026
Date: May 22, 2008
Subject:
Information on Slight Vehicle Movement In Park At Start Up After Cold Soak
Models:
2009 and Prior GM Passenger Cars and Light Duty Trucks (including Saturn)
2009 and Prior HUMMER H2, H3
2009 and Prior Saab 9-7X
with Automatic Transmission
Some vehicles may rock or move slightly forward or rearward while in park at start up after cold soak. This condition may be accompanied by a clunk noise. This is a slight movement that is more often seen visually, rather than felt, when viewed from the outside and using the auto-start feature, if equipped.
This slight movement is due to the residual transmission fluid in the clutch packs that creates a partial apply on start up. This movement is stopped by the parking pawl and/or transmission fluid exhausting completely from the clutch packs.
This slight movement has no adverse affects on the transmission and no repair should be attempted. This condition is normal. This can be verified by comparing with another identically built vehicle under the same cold conditions.
To prevent this condition from occurring, the parking brake should be utilized as per the Owners Manual recommendations anytime the vehicle is parked.
hope this helps
Old 11-29-2010, 01:35 PM
HawkZ28's Avatar
Perfect! THANKS for the info!
How Does A Thermostat Work? cobalt327 Hotrodding Basics 16 03-16-2010 06:32 AM
1968-1969 olds 455 engine is this good and how can i id 1968olds455HO Engine 5 09-02-2009 11:53 AM
SF oil???? n-gin Engine 6 07-09-2008 01:37 PM
cam spec & engine starting stand & email migraine8626 Engine 3 10-03-2007 05:53 PM
Starting long-sitting engine Oldsmoblily Engine 3 06-14-2002 02:07 PM
