Shifter move
That might be a tough go. You can try to mount the shifter forward of the reverse arm of the trans, This would require reverse to now be engaged in the opposite direction. The reverse rod is already rather short.
This approach also puts the shifter further outboard as well as forward which might encroach upon your leg room and acces to your gas pedal. I don't know if my picture adds any value, but I've had to cut and reweld my shifter to move the shift lever further to the right and a bit forward for leg room and seat clearance. |
You may need to make a custom bracket to move the shifter fwd and use some shorter shifter rods to make it work..You can get rod ends and sleeves that would work for that and make for a smooth shifter..
Sam
You could use a bench seat shifter handle like this.
Hurst Chrome Shifter Stick Handle Bench Seat 1955 1956 1957 Chevy Bel Air Nomad | eBay |
Found you another option if you have room for it.
T&F Shifter |
shifter
I spent a couple long evenings making new brackets, reworking the shifting rods heating and bending the shift handle to get it all to work. I have A packard trans in one of my roadsters, no one made a shift kit for it. S 10 T 5's have a foreward shift handle. But it's a toss up whether to sell what you have to put in a T 5.
| 4 speed Muncie shifter | speedydeedy | Hotrodding Basics | 13 | 04-07-2010 07:29 PM |
| muncie shifter probs | bigtim | Transmission - Rearend | 2 | 05-06-2006 08:50 AM |
| Muncie shifter adjustments needed? | Jims64 | Transmission - Rearend | 2 | 12-21-2004 11:01 PM |
| 5 speed tranny with forward shifter? | Warm_Spit | Transmission - Rearend | 2 | 08-13-2003 08:09 AM |
