fouled up plugs - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2012, 02:56 PM
fouled up plugs
Hey how yal/ I"ve got edelbrock 600 and had to put n three sets plugs n three weeks the plugs were fouled from carbine think edelbrock putting n to much fuel?
Old 02-28-2012, 03:09 PM
techinspector1's Avatar
Wiki Edits: 326
Tee off at the carb inlet. Run a small diameter copper line back to the firewall, up past the hood lip and to the cowl. Temporarily mount a 0-15 psi liquid-filled, mechanical fuel pressure gauge on the cowl with tie-wraps, duct tape or whatever it takes for you to view the gauge through the windshield while you drive. Edelbrocks will not tolerate over 6 psi and will run best with 5 psi in my experience. Find out what the pressure is before you try to correct it.
cleaning fouled plugs 001mustang Engine 11 02-06-2011 07:40 PM
too much fuel + fouled plugs bigdog7373 Engine 10 07-22-2010 02:08 PM
Fouled spark plugs tahats Engine 6 02-16-2010 05:16 AM
gas fouled plugs, trying to find the cause??? eatonde Engine 14 10-03-2008 09:21 AM
Will fouled plugs cause this. Rubberman2003 Engine 23 12-15-2003 01:11 PM
