what would cause three plugs on a mild 350 to foul out on the same side of the motor it has new super coil, good wires and good connections, the rest of the plugs are a rusty brown color. the ones that fouled , look like they have been soaked in gas
i would first check to see if your are even getting spark to those three plugs. pull 1 plug at a time, plug it into the spark plug wire and ground it to the block or frame have someone crank the key and check for spark repeat the process on the others . you could have a bad cap or rotor also check the gap
yea i think its fubared but im still gona tear it down and if it needs rebuilt what do yall think of the pre balanced crank and pistons kits.from eagle or scat
chevy 350, im probably going to punch it out to 60 over put forged and balanced pistons crank and rods, solid roller cam have the heads ported and polished
Ditto, dont bore the engine more than it needs to be. The extra power from the extra five or so cubes isn't going to make much of a difference.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
