fouling out the plugs - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-04-2008, 08:01 PM
Casperdude898's Avatar
my motor keeps fouling out the plugs and i have no clue why. no oil on the plugs. they just go out after about 3 weeks, all 8. and idk why can anyone help?
Old 08-04-2008, 08:53 PM
Some engine specs would not hurt at all
Old 08-04-2008, 09:31 PM
its a 350 bored 60 hyp. flat tops 60 cc chambers duntov 33 cam holley 650, bout 10.5:1 comp. with about 350 miles on the motor if that
Old 08-04-2008, 09:36 PM
im not to sure on this but i've heard that excessive spark causes the spark plugs to go bad earlier..but like i said im not to sure on this..
Old 08-04-2008, 09:39 PM
oh yeh, i have a stock hei distributor if that helps any
Old 08-04-2008, 09:44 PM
life is a temporary assignment
Make sure your carb is not dripping down into your motor.when stopped.
Old 08-05-2008, 06:10 AM
Marcel
Last journal entry: Choo-choo town
fouling out plugs
Is there any way to check a plug with a meter ? You know like if its had to high of power or low that mite change it operations.
Old 08-05-2008, 06:42 AM
SSedan64's Avatar
I don't think high power hurts plugs internally that much. It just erodes the eletrode & ground strap much quicker. Never heard of a ohm/resistance meter test for plugs? Maybe, not sure?
Old 08-05-2008, 06:54 AM
malc's Avatar
Living At The Speed Of Life
I cured the same problem by installing a new power valve.
I have a complete MSD setup, no problems with too much "power".
In fact Iīve been led to believe a nice fat spark keeps the plugs from fouling.
My bad power valve wetted the plugs so bad it ran like a pig when idling.
Old 08-05-2008, 05:51 PM
what kind of plugs are you using and what is the gap set at?
Gas fouling plugs Turkey Engine 5 09-10-2006 09:40 AM
Gas fouling on just 2 plugs. machine shop tom Engine 25 08-21-2006 09:24 PM
excess oil fouling plugs gilby246 Engine 4 05-20-2006 09:44 AM
SBC Still fuel fouling plugs, Losing my mind! 67 Deuce 4 Me Engine 9 09-02-2005 08:56 PM
plugs fouling, cat worries, and more - help? joe99 Engine 9 01-23-2004 07:16 PM
