Found a couple of Qjets? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-17-2012, 10:03 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Here is the word for preventing shaft wear on any carb. Set up properly, shafts should never wear out. set up improperly (done more often than not) shafts will wear out very fast. Just envision the forces on the shaft with each spring orientation. You want the spring force to be directed somewhere else, not at the shaft.
Last edited by willys36@aol.com; 08-17-2012 at 11:09 AM. Reason: image doesn't show
The Following User Says Thank You to willys36@aol.com For This Useful Post:
raguza123 (08-17-2012)
  #17 (permalink)
Old 08-17-2012, 07:29 PM
Grease_Fever's Avatar
68 Pontrolet
Good stuff!
Found a couple more of my dads sales tools from 1972 Chevrolet motor division. MARTINSR Off-Topic 1 11-18-2011 07:34 AM
couple new ones johnnyjalopy Hot Rod Art 1 09-07-2010 08:07 AM
Need a couple dimensions 1923sst General Rodding Tech 6 12-11-2006 08:51 PM
Old couple 87442lover Hotrodders' Lounge 5 06-26-2004 11:45 PM
Qjets Ain't they great Mertz Engine 18 08-16-2002 12:53 PM
