We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 03-21-2005, 08:50 PM
mercflathead's Avatar
mercflathead mercflathead is offline
FLATHEAD FOR LIFE
Found a crack in the Number 6 cylinder
I got a call from the shop thats working on my flathead, the guy told me he found a crack in the #6 sleeve going up to the deck lid the crack then goes across the decklid into a intake valve. The crack can repaired but I don't know how much it'll cost me? should i go and find another flathead?
Pat
Old 03-22-2005, 09:07 AM
Max Keith's Avatar
Max Keith Max Keith is offline
cracked block
If the crack were contained only in the cylinder, I would recommend having the cylinder sleeved, however, since it goes up into the valve bridge work, I think the better solution would be to find another block. You could probably repair your current one but, at what cost? And if its not done properly, the crack will continue to grow.
Old 03-23-2005, 11:53 AM
FLATHEAD FOR LIFE
help
come on yall i need help with this.
pat
Old 03-24-2005, 05:34 PM
TooMany2count's Avatar
TooMany2count TooMany2count is offline
A Half Crippled Old SOB....
TooMany2count's barnstar
Wiki editor
Last wiki edit: GM Build Codes
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
Old 03-26-2005, 12:16 PM
Nailhead2x4's Avatar
Nailhead2x4 Nailhead2x4 is offline
.....number one choice is get another block. If there was no choice then chance the fix. But it will always be in your mind is the crack fixed ok or will it show up again ? The sleeve will solve the cyl problem, but the deck crack is not guarenteed to not haunt you later.
Old 03-26-2005, 12:34 PM
NAIRB's Avatar
NAIRB NAIRB is offline
Have It Fixed
Most flat heads are cracked, so I would have it fixed. I would just pin the crack with lock n stitch pins and sleeve the cylinder. I've done it before, and it's not a tough deal to do.
Old 03-27-2005, 09:43 PM
FLATHEAD FOR LIFE
I have desided because of the crack on the deck lid, and the cost of fixing it I have decided to go with a OHV motor, but i still ant that 50's look. I have a running 292 y block, but i can't realy find any high performance parts for it. Or my other choice would ,maybe be a 390 or a 400 bigblock FORD ONLY.
Help
Pat
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Found a crack in the Number 6 cylinder"
crate chevy 302??? Vancouver Grand Prix Engine 84 09-20-2009 08:13 PM
62 booster/master cylinder ss62 Body - Exterior 3 07-29-2004 03:56 PM
Help with continuing master cylinder problem chris57 Suspension - Brakes - Steering 3 09-30-2003 02:35 PM
missing casting number? 78importbeater Engine 5 07-22-2003 09:45 AM
Decipher Block Casting Number rickharris Engine 2 08-28-2002 02:15 PM
