Found a front clip donar - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2005, 11:58 PM
garretthes's Avatar
Last journal entry: Rear Axle swap #2 (74 Camaro) part 6
Found a 79 camaro at a local boneyard. He wants $100 for the front clip. I of course have to remove it. What should I take with me for tools? Will I need to torch anything. He said he thought it would unbolt at the firewall.
This is going under my 59 Suburban.
Old 04-30-2005, 06:14 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Tools to take
Rachet set and sockets..those bolts that hold the clip are fairly large..Combination wrenches..screwdrivers and pry bars..Torch is good to have..sometimes things are just rusted shut and the hot wrench may be needed..
A helper as that thing is fairly heavy..maybe a small jack and jackstands..Can't think of much else..
The sheet metal may need to be pulled..to get at the clip..Hopefully this is not all tha tfar from home if you need to run back for something..and the visa card if you need to get something in the way of a tool that you do not already have..
Bout all that I can think of..
OMT
Old 04-30-2005, 07:39 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Have you ever thought of looking at some of the 80's Chevy trucks? The complete suspension on the '87 that I had unbolts complete from the frame and rolls right out from underneath. So it might be more easily adaptable to the 'Burb than the Camaro clip. Just a suggestion that you may want to look into.
Kevin
Old 04-30-2005, 10:54 AM
garretthes's Avatar
I have see the pix and a good write up of the swap from a 79 camaro. At this point I'm just going with what I know.
mustang front clip swap 2wld4u Body - Exterior 5 11-02-2003 09:07 PM
Removal Of Front clip 72 nova? Pro1972nova Body - Exterior 1 03-02-2003 08:50 AM
Volare front clip BobsRods Suspension - Brakes - Steering 2 11-30-2002 02:49 PM
camaro front clip install slider in wa Suspension - Brakes - Steering 2 08-27-2002 10:17 AM
