found an ingersoll 3 pphase 240v compressor for a steal - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-03-2011, 05:55 PM
err err is offline
found an ingersoll 3 phase compressor for a steal
thing is in perfect shape, well maintained, but i have no clue if i can run it.
obviously i would need to have a dedicated line and breaker put in, but is that possible?
i want overkill so i NEVER have to worry, i want top of the line, and the price is right.
Old 07-03-2011, 06:33 PM
If you want to use it at a home shop, you will have to have a 3 phase converter.You won't have 3 phase available unless you're in a commercial building, and maybe not then. Converters aren't cheap. There are several types. Maybe do a search for pricing to see if it's going to be worth it. Or if you can get a single phase motor with enough power and change that.
Old 07-03-2011, 06:34 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
Have you thought about how your going to run the compressor?
Anyway you'll need a phase converter of some sort, either home made or bought, they cost about $200. & up.
Rich
Old 07-03-2011, 06:41 PM
It's cheap because you will need to replace the motor to operate it on single phase power! You can not run run a three phase motor on residential power without using a phase converter or VFD either of which is not a real option in the case of a compressor. There are two types of phase converters, static and rotary, but the static converter will not allow full power nor does it operate very well under the frequent start cycles of compressor duty and it will also cost about 1/2 as much as a replacement motor. The other type, the rotary, would probably run the compressor OK but it would cost quite a bit more than a replacement motor plus the hassle of installing the thing. A VFD (Variable Frequency Device) might work but it too would cost twice the price of a replacement single stage motor, VFDs are not a good choice for compressor duty anyway. Three phase power is for commercial use and you can not get it connected to your home, it would cost a small fortune to do so even if you could. If you have not already bought this thing you best check out what it is going to cost you to get it running, basically figure the price of a single phase motor of the same HP rating.
Old 07-03-2011, 06:49 PM
Yup.. I looked at them myself.. However, if it's cheap ENOUGH, and you can probably find a used motor on Kijiji or something (What is it, 7.5hp or something?) then I say go for it!
Old 07-03-2011, 06:55 PM
Originally Posted by richard stewart 3rd
Hi
Rich
For $200 you will get a static converter that will only allow the motor to produce 2/3 of the power plus they don't work well at all with the frequent high torque start loads of a compressor. It is possible to build a rotary converter of sorts using a static converter and a three phase "idler" motor in addition to the compressor motor, this would be similar to a true rotary converter but probably not suitable for the high start loads of a compressor-plus combining the cost of the converter with the idler motor will cost more than a replacement single phase motor. If that three phase compressor is 5 HP then it will take a rotary converter in the $400 to $600 range to operate and if it is 7 1/2 HP he could be looking at upwards of $1000 for a converter that would handle the job, if it is 10 HP, well just forget it. Basically some three phase equipment runs just fine on a phase converter but compressors are usually a PITA to get to operate properly using a converter besides a replacement single phase compressor duty motor is MUCH simpler and in all likelihood a lot cheaper than a phase converter that would be suitable for the job, one of those little $200 static converters will not get the job done for a compressor even if it is the right power rating.
Old 07-03-2011, 07:19 PM
oldred
Thank you for the information. I enjoy reading what you post, as they are always well written & informative.
Thanks again
Rich
Old 07-04-2011, 04:59 AM
err err is offline
it looks like the motor says it can be run at 2 different voltages
i will probably get it and if it doesnt work for me, sell it, or use it at the shop
thanks for the info
Old 07-04-2011, 06:06 AM
thanks for the info
Sure it can be run at two different voltages but so can a lot of single phase motors, that has absolutely nothing to do with what we have been telling you! I know what you are looking at on that motor data plate but 240 volts single phase and 240 volts three phase are NOT the same thing! You can't run that thing on residential power no matter what voltage the motor is wired for, it's three phase and you don't have three phase power available. It's your money so do as you like but you have been warned it is going to cost a bundle to get that thing to run at home.
Old 07-04-2011, 07:44 AM
Wiki Edits: 27
costs vs usage
My step son works for an oil dist-gas station Co. They replaced a big compressor in one of their locations so he brought the old one to the house. I has a 3 phase 8 hp 440 v motor, I haven't found a single phase 220 V motor yet that would handle it. . A rotary converter to run it would cost $ 2 k and require $ 400 in wiring. A neighbor has 3 lathes in his shop, He has offered to sell me the big one,, 18, in by 8 ft bed with a 3 phase motor.I still haven't decided if I want to get both the air comp and lathe set up in the 4 car garage at the house. .. We put in a 3 phase irrigation system on one of the farms last year. the power company charged us $ 4 k to install new transformers. a step son is an elect contractor and our cost with me helping was $ 1500 for the rest of the elect panel, breakers and wiring, WE have a $ 1000 a month basic electrical charge even if we don't use any power. the power companies don't like large loads being added in a residential area, It can cause problems with old transformers running 3 or 4 houses. interference from start up loads and HF tig welders etc.
Old 07-04-2011, 08:25 AM
Lathes of 5 HP or less are much easier to run with a phase converter than an air compressor and in fact work just fine on the much cheaper/simpler static converters. Since a lathe is a light load start-up machine and is started only once during operation the static converters are an ideal solution to the three phase/single phase problem. The reduction in power that results from using a static converter is usually no problem on a machine like a lathe or mill and is a very simple and economical way of running these machines.
BTW, that's a good size lathe and would be VERY useful! I have a 14x40 (3 HP three phase on a static converter) and I still find myself needing more swing. With the gap removed from the bed I have a 21" swing but it is limited in length by the length of the gap and of course rigidity is also compromised when the gap is removed, you would have none of those problems with that big swing and bed length!
Old 07-04-2011, 08:32 AM
err err is offline
even running at less than optimal output, it is probably a cheaper solution than something else
it runs 24 cfm at full power
i am getting it for 500 and its mint
im hard pressed to see a reason not too, and i can just sell the motor on my ebay store and swap for a different one, and have a banging ir 80 gallon thats mint, or get an inverter/converter
i wont be losing money, ill def be able to break even i think.
i am not saying you guys are wrong, im sayin just because i dont know much now doesnt mean its a problem for me
i buy and sell **** all day long, its my job, if it doesnt work out for me nbd
Old 07-04-2011, 09:22 AM
It seems your mind is made up already but you obviously are not listening to what you are being told! You CAN'T run that thing on a static converter so running it at reduced power like you mention will NOT work, it will for some light start load equipment like a lathe or mill but NOT a heavy start load air compressor! Besides even after starting a compressor motor reaches a much higher percentage of it's rated power before shut-down than most equipment so it will NOT operate properly on reduced power, if you don't burn out the converter then you will surely burn out the motor if you attempt to run it at reduced power on a compressor.
An inverter converts DC to AC is of absolutely no use to convert three phase AC power to single phase AC and a rotary converter will cost more than a new motor
If you are getting it for $500 then you will probably be able to buy a new motor and come out ok, just bear in mind that a three phase motor will bring only a small part of what a similar power single phase motor will sell for. You will also need an electrician to install the new motor and switch so that it is wired correctly. A new motor is going to be your only real option.
You still have not mentioned what the HP rating is and if it is more than 5 HP you may have more serious problems than just converting three phase to single phase. A 7 1/2 HP single phase motor is going to be very expensive to buy and to wire for and if it is more HP than that then single phase is just not practical. You can not run a lesser HP motor without also reducing the load by slowing down the pump with a pulley change but when you do that you MUST do it properly and even then your performance will be reduced accordingly.
Old 07-04-2011, 09:55 AM
I can't really add to what oldred said, but....
To sum it up.. It won't work.. It's not just that it will run at reduced power.. It just won't work!
BUT, (And also as oldred said) you can sell the motor, and buy a single phase motor.. But be warned nobody wants a 3 phase motor.
AND, as oldred was alluding to (Why did I even write this message, haha), buying the motor isn't the only cost here! If it's 5hp, you need to run 10 gauge wiring, which is pretty expensive.. If it's 7.5, you need bigger gauge, which, as you guessed, is far more expensive.
That doesn't mean much if the breaker is beside the compressor, but if it's not, be warned!
Old 07-04-2011, 10:18 AM
Honestly it is not that I am trying to just discourage the sale of this compressor it is just that I have seen people fall into this trap several times in the past. The OP seems to be disappointed that everyone did not congratulate him on finding a good deal but the fact is that compressor is not the "Steal" he seems to think it is. Is it a good deal? Probably, IF the buyer is aware of exactly what he is getting into and from the OP's comments, such as running on reduced power and using a converter in spite of having it explained why that won't work, it is obvious he does not fully understand what is involved. It's his money and his decision and he probably can make this thing work, others have, but it will most likely cost twice the selling price if he's lucky and that's for a 5 HP set-up. If it's 7 1/2 HP then the final cost gets to be questionable as to whether it actually is worth it or not. For a 5 HP two stage (I assume it is two stage) 80 gallon tank IR compressor $1000 is not a bad price if he can get it going PROPERLY for that amount but that is of course for a used compressor. Obviously his mind is made up and I wish him well, my comments were meant more for general discussion more than anything else since this subject has come up before.
questions about 80 gal 5hp ingersoll rand industrial compressor richie ross Garage - Tools 9 03-22-2010 08:43 AM
ingersoll rand 4000 series 7.5 hp air compressor d&c repairs it all Garage - Tools 2 11-06-2008 06:07 PM
Ingersoll Rand Compressor Recommendations daveh Garage - Tools 8 02-02-2005 02:38 PM
Ingersoll Rang Compressor Recommendation daveh Body - Exterior 7 01-10-2005 06:45 AM
Ingersoll Rand Compressor ID banjerpicker Body - Exterior 1 06-28-2004 12:12 PM
